Good Oil Pressure ... >
Old 11-08-2004 | 06:19 AM
offthefront's Avatar
Default Good Oil Pressure ...
Went with a buddy yesterday to look at a 292 Formula with 454's and supposely Port Motor was just rebuilt and Starboard motor last year. Motors ran ok but I noticed even at 4000rpm the Oil pressure was only about 25 lbs and not really rock steady and at idle would drop to about 20lbs ... ....I know my 311 runs 60lbs underway ....I think these motors are very tired .... opinions?
offthefront is offline
Old 11-08-2004 | 08:35 AM
Infomaniac's Avatar
Default Re: Good Oil Pressure ...
I would cut the filter open and look for debris. Verify that the pressure indicating system is functioning properly.
I would not feel comfortable with that oil pressure. Oil is fresh?
Infomaniac is offline
Old 11-08-2004 | 09:36 AM
mopower's Avatar
Toxic FORMULA
10lbs per 1000 rpms. 4000 should yield 40lbs min.
But on a brighter note...I had one that would start ot 50 lbs , run for a while it would drop to 25/30...slow to an idle and it wouldn't change. Turned out to be a bad sender If the o/p was bad it should have dropped more when retuning to idle.
mopower is offline
Old 11-08-2004 | 10:24 AM
all the fluids were fresh ....VERY fresh .....told my buddy ...move on to the next one .....
Old 11-08-2004 | 06:25 PM
articfriends's Avatar
Before i worried about anything i'd screw a mechanical gauge in sender port and measure actual oil pressure,Smitty
articfriends is offline
GoCiggie31
7
08-19-2007 06:07 PM
dockrocker
17
08-05-2005 09:30 PM
FlyFast
13
05-10-2004 11:39 PM
Racing_Fan
7
09-17-2002 09:19 AM
