Slick 50 TRS Drives >
Slick 50 TRS Drives
Slick 50 TRS Drives
Old 11-10-2004 | 09:19 AM
gripit's Avatar
Default Slick 50 TRS Drives
I bought a Cigarette 31 454's with TRS Drives. The previous owner told me he has been putting Slick 50 in the TRS Drives as lube for the last 7 years. Has anyone ever heard of this? Would you continue or swith to some other lubricant?? Thanks
gripit is offline
Old 11-10-2004 | 09:27 AM
Biggus's Avatar
Default Re: Slick 50 TRS Drives
About 10 years ago Hot Boat mag did a test of all the popular oil additives at the time.
The results proved that adding Slick 50 actually reduced lubrication properties. All the oils tested performed better on their own.
I'd run nothing but Merc Hi Perf gear lube.
Biggus is offline
Old 11-10-2004 | 09:45 AM
mcollinstn's Avatar
Slick 50 in a gearbox application pretty much doesn't do anything. Not anything good. Not anything bad.
In a motor application, though, it actually can do bad things. Such as build up a plasticky coating on anything exposed to extreme temps (old style turbo bearings in particular). Can also settle in rubber seals and combine with other crap to starve the sealing lip of oil, causing premature wear of the seal.
I'm confident your drives weren't hurt.
But I see no reason to consider using it yourself.
mcollinstn is offline
Old 11-10-2004 | 01:03 PM
gripit's Avatar
Is there anything better than Quicksilver High Performance gear lube??? What is the best for TRS Drives???
gripit is offline
Lofty
Swap Shop
1
07-31-2008 10:29 AM
grimmy
Drives and Lower Units
8
09-27-2007 06:35 AM
r-boat
01-10-2004 11:37 AM
Dean Ferry
11-27-2002 08:09 AM
r-boat
01-18-2002 12:20 AM
