Hustler 500efi engine tear down & Build Up >
Old 10-18-2005 | 09:40 PM
  #251
Strip Poker 388's Avatar
Rob
Default Re: Hustler 500efi engine tear down & Build Up
Attached Thumbnails Hustler 500efi engine tear down & Build Up-heads-intake-009.jpg   Hustler 500efi engine tear down & Build Up-s-019.jpg
Strip Poker 388 is offline
Old 10-18-2005 | 09:49 PM
  #252
Rob
One thing I noticed the innercooler fitting when ya put a Earls #12 fitting there the temp sender will not fit in the spot provided Had to put it in the thermostat housing It could of been put a little lower or in a different spot and it would of fit and been cleaner install.
Attached Thumbnails Hustler 500efi engine tear down & Build Up-copy-parts%3B-water-neck-006-large-.jpg   Hustler 500efi engine tear down & Build Up-copy-parts%3B-water-neck-008-large-.jpg   Hustler 500efi engine tear down & Build Up-engine-bildge-041.jpg
Old 10-18-2005 | 09:55 PM
  #253
Rob
On the back of the intake there is a lot of stuff going on back there, atleast is hidden some . All the wiring will be bunched up here also
Attached Thumbnails Hustler 500efi engine tear down & Build Up-heads-intake-009.jpg   Hustler 500efi engine tear down & Build Up-parts%3B-water-neck-010-large-.jpg   Hustler 500efi engine tear down & Build Up-parts%3B-water-neck-007-large-.jpg
Old 10-18-2005 | 10:00 PM
  #254
Rob
Here some of the Whipple hardware , Nice stuff.
Also some of my plumbing stuff,Got to make it pretty even if it cant run
Attached Thumbnails Hustler 500efi engine tear down & Build Up-4-1-05-048.jpg   Hustler 500efi engine tear down & Build Up-s-006.jpg   Hustler 500efi engine tear down & Build Up-blowers-intake-bearings-2-009.jpg
Old 10-18-2005 | 10:06 PM
  #255
Rob
Whipples mounted
The water neck I had made with the #12 bungs welded on so I can run the braided stuff on every thing .I just pollished the stainless bung and weld to blend in,
The bottom of the 3.3 Whipple , The screw
Attached Thumbnails Hustler 500efi engine tear down & Build Up-3-15-05-004.jpg   Hustler 500efi engine tear down & Build Up-engine-bildge-041.jpg   Hustler 500efi engine tear down & Build Up-015.jpg
Old 10-18-2005 | 10:25 PM
  #256
Rob
The 2 Whipple kits came in the boxes these 3 boxes very well pack with that expand a foam. Everything was bubble rapped , there wasn't a single scratch ,dent on anything .I was surprised how well they packed the stuff
The kits came with every thing you would need for a stock 500efi install . There was even some extra stuff. i even has some left over stuff. I ordered mine thru Mark at Precision Marine in Louisiana without the fuel system,diff pulleys etc.I knew I was going to run it on Marks Dyno and he was doing the ECM for me and the way he does it on the Dyno it exactly the same as it would run in the boat all the ascoryes , I even had fluid flowing thru the power steering pump.using my fuel system on the dyno meant I didn't have to touch it when I put it in the boat
The one thing wish Whipple did was Polish this plate. I ask Dustin he said I could not take it apart Oh well
Attached Thumbnails Hustler 500efi engine tear down & Build Up-s-025.jpg   Hustler 500efi engine tear down & Build Up-whipples-008.jpg   Hustler 500efi engine tear down & Build Up-whipples-009.jpg
Old 10-18-2005 | 10:31 PM
  #257
Rob
One of the distributors has a hard spot in it. I took both apart and cleaned them up . the a bronze bushing I polished it up , lubed them and put back together.
Attached Thumbnails Hustler 500efi engine tear down & Build Up-3-15-05-001-large-.jpg
Old 10-18-2005 | 10:45 PM
  #258
Rob
My MSD brackets I made out of stainless steel.Put the riv[blind]nuts in it . I had made them out of aluminum last year and the cracked and water spotted.
These mount right above the ECM on the stock mer 500efi bracket . I like it better there and it keeps the motor cleaner looking . Ive seen where Teague mounts his on the front of the motor This keeps the wires shorter and all the ignition in the same place and stainless bracket polished will look like chrome even though ya cant see it
Attached Thumbnails Hustler 500efi engine tear down & Build Up-bolixi-race-prop-etc-007.jpg   Hustler 500efi engine tear down & Build Up-bolixi-race-prop-etc-010.jpg   Hustler 500efi engine tear down & Build Up-bolixi-race-prop-etc-009.jpg
Old 10-18-2005 | 10:48 PM
  #259
Rob
Attached Thumbnails Hustler 500efi engine tear down & Build Up-engine-bildge-032.jpg   Hustler 500efi engine tear down & Build Up-4-1-05-034.jpg   Hustler 500efi engine tear down & Build Up-4-1-05-037.jpg
Old 10-18-2005 | 10:52 PM
  #260
Rob
The last pick you can see where it sits , the wire tye is holding the msd wires under neath. I will shorten them this winter and get rid of the wire tye
Attached Thumbnails Hustler 500efi engine tear down & Build Up-4-1-05-038.jpg   Hustler 500efi engine tear down & Build Up-engine-bildge-038.jpg   Hustler 500efi engine tear down & Build Up-rez-engine-027-large-.jpg
