Hustler 500efi engine tear down & Build Up >
Old 10-19-2005 | 12:42 AM
  #271
Strip Poker 388's Avatar
Rob
Default Re: Hustler 500efi engine tear down & Build Up
Here is my post on spinning the Whipples.They sure make a lot of boost early in the rpm band
Videos
http://www.offshoreonly.com/forums/s...hlight=whipple
Rob
Strip Poker 388 is offline
Old 10-19-2005 | 12:56 AM
  #272
Rob
Road trip. It doesent look like 1809 TQ does it ?
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-port-010-large-.jpg   Hustler 500efi engine tear down & Build Up-dyno-port-015-large-.jpg   Hustler 500efi engine tear down & Build Up-dyno-port-012-large-.jpg
Old 11-01-2005 | 11:17 PM
  #273
Rob
Ballance cards
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-sheet0001-medium-.jpg   Hustler 500efi engine tear down & Build Up-dyno-sheet0002-medium-.jpg
Old 11-01-2005 | 11:19 PM
  #274
Rob
Machine shop bill
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-3-large-.jpg   Hustler 500efi engine tear down & Build Up-dyno-4-large-.jpg
Old 11-01-2005 | 11:22 PM
  #275
Rob
cam card
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-cam-card-medium-.jpg
Old 11-01-2005 | 11:25 PM
  #276
Rob
Head flow is so/so. One set was a little better
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-head-1-medium-.jpg   Hustler 500efi engine tear down & Build Up-dyno-head-2-medium-.jpg
Old 11-01-2005 | 11:27 PM
  #277
Rob
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dyno-head-3-medium-.jpg   Hustler 500efi engine tear down & Build Up-dyno-head-4-medium-.jpg
Old 11-02-2005 | 06:12 AM
  #278
Which and what was don to your heads again? At .5-.6 lift there is In-300-345 and Ex-200. I think AFR and ported others will do almost 400In/300Ex at the same lift.
cobra marty is offline
Old 11-02-2005 | 09:20 AM
  #279
Rob
There stock heads with alittle clean up .The picks are back in this thread
Old 11-02-2005 | 12:02 PM
  #280
Linster's Avatar
Off the Radar
How can you sleep at night knowing the MSD wires are hanging on the back of the engine? I would pull both motors and start over!
JK!!
They look great.
Linster is offline
