Hustler 500efi engine tear down & Build Up >
Old 11-23-2012 | 11:45 PM
  #391
Strip Poker 388's Avatar
Rob
mo bearing wear
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-056.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-057.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-059.jpg
Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-062.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-064.jpg
Strip Poker 388 is offline
Old 11-23-2012 | 11:50 PM
  #392
Rob
dual purpose bench
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-078.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-079.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-080.jpg
Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-081.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-082.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-083.jpg
Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-091.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-093.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-109.jpg
Old 11-23-2012 | 11:57 PM
  #393
Rob
2 2 many
Attached Thumbnails Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-095.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-102.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-109.jpg
Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-051.jpg   Hustler 500efi engine tear down & Build Up-dicks-rem-700-%24349.00-114.jpg
Old 11-24-2012 | 11:03 PM
  #394
Rob
Im thinking the dark spot may be caused by the oil pump stud?
Old 11-24-2012 | 11:08 PM
  #395
Rob
I t looks like that the journal has some bearing transfer
Old 11-27-2012 | 08:28 PM
  #396
Rob
These are 2007 builds,about 4 summers. Im trying to figure up the hours from notes,
What do you all think? little trash
click on pick to zoom in
Old 11-30-2012 | 08:31 AM
  #397
Those look a little bit like mine, but mine had only 30 hours on them, as opposed to 4 summers. That rear main looks a little bit like it had a hot spot in that dark area. Yes, it does look like there might have been some small particles that got through there, and some wear. Maybe a little fuel dilution on a supercharged application?
Budman II is offline
Old 12-08-2012 | 03:29 PM
  #398
Rob
I had sent my rings back to Total Seal, They said there is a little signs of fuel wash,which I know the motor is real rich,little detonation on the bottom of the ring cupping which I know I'm on the edge,and they are close to needing replaced,The molly looked good,Keith said that they look about normal for a marine blown engine at this power level with this many hours.He did recommend a diff ring that has a better stronger top ring.He did say make sure tofollow the bore and honing directions that Dart provided to get a good ring seal.
CT9190-255 TNT 1/16 4.500
Ring gaps are good not showing any butting and the leak down was still good The puke tank on this motor just had a little oil mist in it,so blowby wasn't bad even though how loose it was.
I been cleaning up the old block and all the other parts,going to sell.
Block w/ JE pistons 4.530 gen 6
2 sets Crane tappets
manley push rods
2 sets guide plates
2 sets comp 929springs
2 sets retainer comp w/ loc
2 sets manley valves
Crane rocker arms
2 sets rocker arm studs
4 oilpumps w/ meling/mporoso pick up
2 sets arp head bolts
I've pulled the rods apart and the rod bearings are showing a good bit of wear, to me at least,Ill post some picks.
I polished the cam and most of the tracking/marking came out,
Rob
Old 12-08-2012 | 03:41 PM
  #399
Rob
starboard rod bearings
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-12-2012-019.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-066.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-064.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-063.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-062.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-061.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-060.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-058.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-057.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-056.jpg
Old 12-08-2012 | 03:44 PM
  #400
Rob
Piston scuffing
puke tank oil
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-056.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-054.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-051.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-046.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-042.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-033.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-030.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-029.jpg   Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-027.jpg
Hustler 500efi engine tear down & Build Up-hustler-staqr-bearings-12-5-12-010.jpg
