Hustler 500efi engine tear down & Build Up
#442
[ATTACH=CONFIG]505029[/ATTACH][ATTACH=CONFIG]505030[/ATTACH][ATTACH=CONFIG]505031[/ATTACH]I'm going to sell my old Whipple's. They are the 3.3's 2005 w/ 314 hours on them,They were running fine and making boost on both ,one had slack in it like bearing or gear,So I sent in both just for the hell of it.Whipple tore them apart and determined he couldn't rebuild them.That a pin on the drive snout broke and a bolt had backed out snapped off wearing the front bearing plate.The other one didn't. So I just bought new ones so both would be all new and matching.There are 2 people out there rebuilding Whipples/superchargers,I sent all the picks to one and he said they it looks like he can rebuild them,head units are repairable if I can get the broken bolt out of the rotor.or at least make one and use the parts out of the other.He is going by only the picks I sent him that Whipple took,he said he would buy them if I didn't sell them here first.I'm going to send him the compressors and he will determine a price to rebuild or just buy them out right from me.That way we have a 3rd party inspection and price quote to rebuild them.I am no expert and don't know some of the terminology of the guts. I'm being up front with you all,and am disclosing everything . When I looked at them I could see the scaring on the front plate,the Allen head bolt that backed out and broke off,To the rotors don't look bad,the cases has no wear at all that I can see. The inside still has all the machining grooves in it,there's no wear showing like if a rotor touch the case.There are little marks on the rotor where it touched just on the end , it wore the coating off but you can still see the machining marks form when it was new.My new Whipple's I just bought has more wear/clearancing marks than my old ones do now.
This is for the compressors only. This is not a kit
I have also 2 new 2013 Snouts for this I bought before we tore them down. I'm going to try and sell them here or Whipple said they would take them back.
2 Compressors $1000.00 each asis. plus shipping usa only no paypal
2 new snouts $250.00 each
I have all the picks and new picks I took.I can take more if you want before I send them out. I had emailed the rebuilder all the picks from whipple in Jan this year, So ive been sitting on them. I have talked to the rebuilder today. I told him that I would try here first maybe getting more for them to re coop some of what I spent on the New ones.He has offered alitlle less that im asking from just going by the picks.He understood as I know he has to rebuild them and be-able to make money himself. He mentioned to please don't snow ball him with phone calls,So please don't waist his time as he has not seen them in person,
I was told that the 2 broke off bolts will have to be removed,replace the broke pins,1 front bearing plate welded up and re machined flat,and bearings,retime the rotors,
I have the data out of my computers that show all the seconds,minutes at what rpm.almost 200 hours below 1000rpm
Thanks for looking
Rob
Thanks for looking
Rob
#445
0-1000 RPM =128.17 Hours
1001-2000 RPM = 16.50 Hours
2001-3000 RPM= 25.04 Hours
3001-4000 RPM = 37.92 Hours
4001-5000 RPM = 3.36 Hours
5001 RPM and up = 21.55 Minutes
#448
[ATTACH=CONFIG]508741[/ATTACH][ATTACH=CONFIG]508742[/ATTACH][ATTACH=CONFIG]508743[/ATTACH][ATTACH=CONFIG]508744[/ATTACH]
Yea Frank,sold the old blowers,kinda burnout throwing money at it stuff not under my control not holding up. Im going start back on my cars,Ive got the old Blower off my Scarab and going to put it on the Chevelle,Should be fun, start using the cars again.
