Carb question >
Carb question
Carb question
Old 11-22-2004 | 08:28 AM
Default Carb question
The carb on my smal block engine has begun running too rich. It was rebuilt about a year ago and worked fine. Recently I noticed soot on the transom and the smell of excess fuel when ideling. Tried adjusting the mixture screws this weekend. They do not cause any change at all...from screwed all the way in to 3 turns out. Any ideas as to whats wrong?
AGGRAVATION28 is offline
Old 11-22-2004 | 08:42 AM
Biggus's Avatar
Default Re: Carb question
probably a leaky power valve.
Biggus is offline
Old 11-22-2004 | 09:01 AM
Forgot to mention...the idle quality isn't too bad...someone not paying close attention wouldn't notice the slight increase in roughness. Still think its the power valve?
Old 11-22-2004 | 09:08 AM
aero-offshore's Avatar
Usualy when adjusting the mixture has no effect, it's a vacuum leak or dirty needle and seat. Does it stall or idle higher than it did?
aero-offshore is offline
Old 11-22-2004 | 12:59 PM
articfriends's Avatar
q-jet or holley? If its a q-jet i suspect the well plugs are leaking,if its a holley i would pull it off and go thru it,even if its only been a year ago,look for bad power valves or loose jet plate screws,if you rebuild it yourself you can change everything for 50$ worth of parts,Smitty
articfriends is offline
Old 11-22-2004 | 04:48 PM
Forgot to mention, its a Holly 4 barrel. Engine doesn't stall or idle any faster than norman, just slightly rougher. Plugs, transom soot, and smell tell me theres too much fuel going through it. Again, the mixture screws are ineffective. Any other ideas?
Old 11-22-2004 | 08:35 PM
Also check the level of your fuel bowls.
Griff is offline
Old 11-23-2004 | 02:33 PM
Its not the float level....they're set at the right height. Guess I'll replace the base gasket first and if thats not it, attack the power valve.
Old 11-23-2004 | 03:45 PM
robyw1's Avatar
Look down the carburetor while at idle and see if fuel is dripping out of the venturis. If it is then your float level is set a little high.
Put your finger over the primary vent tube. If it stalls the power valve is probably OK. If it does not stall then the bowl is being vented by a blown power valve.
If you had some crud on the needle & seat I believe that it would load up and stall instead of just running rough
Roby
robyw1 is offline
boatfreak
5
07-22-2008 03:02 PM
ak
4
05-17-2008 08:57 AM
WMF
2
05-06-2008 06:36 AM
HyperBaja
01-19-2003 07:49 PM
