Bravo III won't go down >
Old 08-25-2021 | 12:23 PM
Default Drive won't go down
The rams are perfectly clean. They never sit in the water. Fluid has no water or milky look to it. I just built a 3000 PSI test guage and will establish if it is the pump, or the left or right Ram. I will provide feedback once I established the answer.
Thanks for your interest.
Steve
Preferred Steve is offline
Old 09-18-2021 | 08:22 PM
Thank you all for your time in attempting to help me fix this problem. Since last writing, I have resolved the problem. After testing the hydraulic lines at the drive for pressure and testing the rams for pressure, it seemed pretty clear that the problem was the pump. I believe the only problem is the "overload valve" in the bottom of the pump which is supposed to release pressure if a grounding occurs. I wasn't going to go thru the effort to remove the pump and try to replace that valve so I bought a new pump. they are available between $300 and $400 complete. I put the new pump in and I am back in business. Bleeding by raising and lowering a few times and we are good as new. Now I have a spare for parts-hopefully I won't ever need it.
As a note, before buying the pump I removed one of the rams from the drive while the drive was in the full up (out) position. Both rams were connected to the hydraulic lines. I wanted to make sure one ram wasn't holding the other from moving. Upon activating the switch to go down, there was no movement in either ram. This confirmed to me it was the pump.
Thank you again for your time. I love this site!
Steve
berns29scarab
Drives and Lower Units
3
05-10-2008 07:36 PM
berns29scarab
05-07-2008 07:33 PM
mecelec
3
03-24-2008 10:42 AM
baronbob
16
04-16-2006 09:57 PM
B38
1
05-01-2002 03:45 PM
