Trailer Backing Into Garage >
Old 12-17-2004 | 07:44 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Trailer Backing Into Garage
I have a similar problem. Although my boat and trailer together only measure 30'. My driveway is 100' long and only 11' wide. The garage door is offset from the center of the driveway by 2 1/2'. There is a patio and awning hanging off the back of my house that comes to about 15' from the garage. It is just impossible to back all the way down the driveway and into the garage. If it were a straight run it would be easy, but with the offset, forget it. So, to get my boat and trailer in the garage for the winter I back it in as far as I can. Which is just about where the awning hangs off my house. I drop the trailer of the hitch and onto the front wheel on the trailer. I have a winch mounted to the floor in the back of the garage. I hook it up to the trailer and just steer it in from the front by hand while holding the winch controls. Works great..
Vinny P is offline
Old 12-17-2004 | 09:12 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Sean H
strip, you let that thing in your driveway? does it have NOS too?
I borrowed it from my dad while the car was in the shop . I figured I hook it up to see how it sat it down in the ass. It did not move the Bean car much My dad didnt like it either . I told him it made some funny noise's when backing it up the drive way with the trailer breaks on
They are ugly but there fun to drive
Its still funny looking
Attached Thumbnails Trailer Backing Into Garage-chevelle-eng-element-bryant-eng-051.jpg   Trailer Backing Into Garage-chevelle-eng-element-bryant-eng-054.jpg
Strip Poker 388 is offline
Sean H's Avatar
A to Z
i bet a 200 shot would make it much cooler....
Sean H is offline
Old 12-17-2004 | 10:34 PM
Rob
It would probably make all the plastic fall off I would rather have the Dodge mini van I posted in the OT section,runs 12's
The say you can wash out the interior with a water hose
Old 12-18-2004 | 07:13 AM
Sean H's Avatar
A to Z
let me know how that goes....
Sean H is offline
Old 12-18-2004 | 11:26 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Kinda like my setup, as far as manueverabilty. The pic may not show it, but my boat alone also is longer than the front of the 3rd stall to the curb. (8x9 door) I can back it in with no problem and also stay out of the yard across the street. I just start off in front of the neighbors house hugging the curb across the street and slowly make as wide of a turn as possible. I usually have to pull forward to straighen out the truck because I have to have it lined up straight when going in.
US1 Fountain is offline
Old 12-18-2004 | 03:15 PM
'05 Concept SF23
A 43 FT Black Thunder on an aluminum trailer w/o drive guard and no drive boxes is 47 to 48 ft long. Also the Black Thunder is 9 1/2 FT wide at the cabin entrance to behind the front bolsters. I store mine in a 16' x 16' x 50' pole barn with 14' x 14' roll up door and it fills it up. It takes lots of practice and lots of "when in doubt, get out and look" to get proficient in trailering a bigger boat. Do not get surge brakes on the trailer, go for the electric over hyd disc brakes. Makes backing up much easier.
f311fr1 is offline
Old 12-18-2004 | 05:25 PM
wwwTOPDJcom's Avatar
Originally Posted by Sydwayz
Another option would be picking up a retired airport tug. They are stong as an ox, and maneuver great. You may be able to back it in there, but your pivot point is going to be way farther forward when you come to pull it out of there. Realize a 40'+ boat on a trailer is not going to turn and maneuver for shlt. You are probably going to have to wet down the driveway when turning it so it slides better. I agree with the other guys, that it probably can be done, but its gonna take practice. Can you make the front portion of the garage and the door a few feet wider? Also, when it comes time to just stick the trailer in there, you can remove the wheels/tires off of the back two axles, and it will swing/maneuver much easier. Obvisouly, you can't do this with the boat on it.
an old Jeep works well to and you can find them in the paper cheap
wwwTOPDJcom is offline
Old 12-18-2004 | 05:33 PM
I use a 40 horespower New Holland farm tractor for this purpose. Rear tires are about 40" tall. Easily backs a 12,000 pound trailer. Plus you can use it to blow snow and cut the grass.
Dock Rat is offline
Old 12-18-2004 | 05:39 PM
carney's Avatar
I would have to say, seeing I have never lived in town. Buy 40 acre's and turn that rig around.
carney is offline
