Trailer Brakes ? >
Trailer Brakes ?
Trailer Brakes ?
Old 12-19-2004 | 06:14 AM
carney's Avatar
Default Re: Trailer Brakes ?
formula31, your trailer may not have backing plates , but if you look there should be a small square plate welded to your axle with four holes where they can be added.
carney is offline
Old 12-19-2004 | 06:43 AM
formula31's Avatar
No, that is the part that I dont have. I mis-described what I was asking. That small square plate is what is not there.
formula31 is offline
Old 12-19-2004 | 11:14 AM
Sydwayz's Avatar
Forum Regulator
Well, that sucks if that is the case. My axles had them. My new 3500lb axles were about $200 a peice, made by Quality Axle I think.
Might talk to a local semi-truck trailer repair place. They may can add on the plates.
Sydwayz is offline
Old 12-19-2004 | 11:24 AM
SeaRay Jim's Avatar
Could be that you only need new spindles with the plate for the brake assembly to bolt to.
FYI, the drum brake assemblyies are standard; there is no marine versions. I bought 2 replacements for about $80. Pull the 4 bolts and brake line, bolt up the new, adjust and bleed the lines. Viola', done.
SeaRay Jim is offline
Havasu Cig
11
05-22-2004 07:39 PM
Cord
15
10-08-2003 03:52 PM
jokerswild
6
10-10-2002 02:51 PM
HavasuCat
06-21-2002 10:53 AM
jrocket
03-14-2002 09:27 PM
