Flat tappett? >
Flat tappett?
Flat tappett?
Old 12-24-2004 | 09:59 PM
formula31's Avatar
Default Re: Flat tappett?
Originally Posted by Reed Jensen
Also... a camshaft that pushes flat tappets has more abrupt ramp angles and a pointy lobe. This is because the tappet gives the valve a certain amount of "dwell" while open . Whereas the roller contact with the cam is minimal compared to the flat tappet.. so... the lobe on the cam has a pronounced "dwell" area on the lobe itself. If you saw the two different styles next to each other... it would make sense.
Very true. Its the difference between pointy missle tits and the big round ones. Have a merry christmas.
formula31 is offline
Old 12-25-2004 | 07:06 AM
Crazyhorse's Avatar
Yeah. Check out Madonna with the pointy bra and then check out Queen Latifah. Madonna is the flat-tappet design while Q.L. is the roller design. Dwell on that.
Crazyhorse is offline
Old 12-25-2004 | 01:12 PM
Reed Jensen's Avatar
Nice analogy... have a Merry Christmas... If you still have questions... I'll post some pictures.
Reed Jensen is offline
Old 12-25-2004 | 01:13 PM
Personally.... I'd rather roll on Madonna's points.........
Old 12-25-2004 | 01:52 PM
David's Avatar
The Ford OHV "Y" block engines (239, 272, 292, 312) also used "mushroom" style tappets.
David is offline
Old 12-25-2004 | 08:19 PM
Crazyhorse's Avatar
David, now that you mention that engine family, now I remember them. Man, they were real powerhouses back then. The 312 Thunderbird engine was the hot ticket with the hotrod guys.
Reed, are the pictures going to be here or will you be needing to hang them in uncensored?
Old 12-26-2004 | 12:42 PM
We're talking cam lobes.... not breast lobes...
Old 12-26-2004 | 01:08 PM
blue thunder's Avatar
Ah shoot.... I guess I can cancel my subscription to this thread now....
BT
blue thunder is offline
Old 12-26-2004 | 01:20 PM
I love they way you guys can change a cam question to womens breast shapes. Probably why I love this site!
There are some pretty interesting grinds available today in hydraulic lifter form.
Have you guys seen hydraulic roller lifter failure yet due to the use of synthetic oil?
Seems the roller does not have enough friction to keep turning and develops a flat-spot. We may have to go back to dinosaur oil in some applications.
Edward R. Cozzi is offline
Mkeller
02-09-2007 12:09 PM
Here's Johnny
11-28-2005 04:44 PM
RUSSSR1
Cigarette
11
05-19-2004 08:20 AM
jryan26
Cigarette
15
12-02-2003 12:47 PM
