Fuel Pump
Old 12-26-2004 | 11:52 AM
Dtile's Avatar
Default Re: Fuel Pump
btw, the carbs arent 1050's. I think 750's.
Dtile is offline
Old 12-26-2004 | 11:58 AM
Dtile's Avatar
THough I dont have a boost gauge yet, can you tell the boost by the pully size?
Dtile is offline
Old 12-26-2004 | 03:29 PM
Nope,as Tomcat and others hear have taught me, the boost is really just a result of the restriction in flow that won't pass thru your intake ,heads,and exhaust. You could have a lot of "boost" and low boost measurement by having a very open system or very high readings and not as much effect if you had a lot of turns and bottlenecks. You can of course guestimate the backpressure if you know others with similar heads,intake,exh,pullies,,,and don't forget the cam is very important in the final #'s. Others here can probably do a better job estimating.
cooltoys61 is offline
Old 12-26-2004 | 04:04 PM
KNOT-RIGHT's Avatar
Yep As Cooltoys stated to many variables.
Here are some sites.
http://www.kuhlsuperchargers.com/tech%20p03.htm
http://www.holley.com/HiOctn/TechSer...fo/SCTech.html
You must know the boost before changing pulley size.
If they are non intercooled adding a Chiller will give you the extra horsepower
you are looking for hands down.
Call Inovation they may recall the boat.
Gerry
KNOT-RIGHT is offline
BillR
11
07-29-2022 06:31 AM
HP500Hammer
15
01-30-2008 06:03 PM
jdub
7
03-26-2007 05:06 PM
BillR
4
02-06-2007 03:23 PM
