IMCO shorty on a Fountain >
Old 12-28-2004 | 10:42 AM
aTX427's Avatar
Default IMCO shorty on a Fountain
Has anyone tried a -2 shorty on a 38 Fever or Lightning with a side by side engine configuration? X-Dimension is 17.5".
aTX427 is offline
Old 12-28-2004 | 11:28 AM
sterndrivespec's Avatar
Default Re: IMCO shorty on a Fountain
we put a pair on a 35 fountain and gained 4 to 5 mph
sterndrivespec is offline
Old 12-28-2004 | 11:42 AM
Fountain38SC's Avatar
Buddy's got 1.5 shorties on his 38 with 650's
Fountain38SC is offline
Old 12-28-2004 | 12:41 PM
monsta
I rigged a 38' 1999 with twin side by side 725's , 18" x, with 2" imco's . Spun a set of labbed 32's, 4bld. She ran 102.8 on gps. 5 bld 30x15 1/8 labbed maximus' prop's planned much better, ran 1-2 slower and had a tremendous cruise difference, about 72@4000 rpm verses 60.4 @4000. Best all around wheel. Also tried 5 and 6 bld herrings, and just blew holes in the water, and if planned, they weren't so hotttt. If I can be of more help please call, 516-799-6029.
Old 12-28-2004 | 12:56 PM
KAAMA's Avatar
monsta,
When kind of difference in speed was there going from the standard length Bravo drive to the -2" IMCO shortie? Or were there too many changes done all at once? Thanks
KAAMA is offline
Old 12-29-2004 | 05:53 PM
aTX427's Avatar
Monsta, Do you know what the x-dim was on the boat that you rigged or probably more appropriate question is the distance from the prop centerline to the hull since the prop height was chaged using the lower unit rather than raising the engine? Did you try any of the hydromotive 5-blades on that application?
Thanks John
aTX427 is offline
Old 12-29-2004 | 05:56 PM
aTX427's Avatar
I re-read your post - it looks like 18" x-dim with the -2" shorties. Do you mean the setup was 18" with standard drives then the props were raised 2" using the shorties to simulate a 20" x-dim?
aTX427 is offline
Old 01-03-2005 | 08:28 PM
aTX427's Avatar
Now I am convinced that I need to do something - I re-measured today and my prop shaft centerline is 5.375" below the bottom of the boat. Does anyone have two used complete 1.5:1 IMCO -2" shorties that they want to sell. I could probably go -3" but I believe that I would have to buy an entire IMCO drive.
aTX427 is offline
Old 01-04-2005 | 08:25 AM
baja36ft's Avatar
I might have two sets for sale i am going out this weekend and testing a set on a 36 outlaw
and if they don't work they will be for sale.
baja36ft is offline
Old 01-04-2005 | 02:44 PM
aTX427's Avatar
let me know how they work - either way I am interested
aTX427 is offline
