502 Heads, square or oval? >
Old 01-06-2005 | 08:38 PM
Can anyone tell me about my 502? It is a 99 502 mag mpi(425 hp?) that I would like to pep-up. I would like to upgrade the manifolds to GIL or someone similar. Does anyone know if my ports are square or oval? I think this is a Gen 6? I have also been told to go with a larger throttle body, anyone tried this? Do I have roller cam, or roller rockers?
This is in a 99 Donzi 26ZX. if anyone has any suggestions as to upgrades on this engine please let me know. Any help would be GREATLY appreciated, Heath
please don't say supercharge her because I just bought lakefront and I'm building a new house this summer so the "boatbudget" for '05 will be limited, very limited!
captndonzi is offline
Old 01-06-2005 | 09:25 PM
Default Re: 502 Heads, square or oval?
Stupid answer but save your money until you know where you are at. Then do it right like you want it. You did not buy your property and house with second considerations did you?
Maybe not a bad answer after all.
Welcome to the Board!
As far as your 502 do some research. You will get your answer with a post but you won't learn as much.
BadDog is offline
Old 01-06-2005 | 10:25 PM
Bad Dog,
The reason I ask about the head porting is because I have 2 sets of GIL manifolds that came off my Sonic and I would like to use them if possible, however they are square port.
Also B.D., I don't believe I have owned a boat for over a few months so saving my money till later is usless, just want to have a little fun until someone makes me an offer on this one. Thanks for the welcome, Heath
Old 01-06-2005 | 10:34 PM
formulaz,
what would you call the exhaust "hole" then?
Old 01-07-2005 | 01:28 AM
wwwTOPDJcom's Avatar
cheap speed is to have your prop done.. Darin took me from 67 to 70.6
with a 26 B1 labbing is one of the ones that gets ya something for very little cost.
exhaust will gain you unnoticeable speed less than 1mph, unless you have thur hub
in which case it could be slighty over 1mph.
wwwTOPDJcom is offline
Old 01-07-2005 | 05:42 AM
Looks like your best bet is the exhaust and the prop. Depending upon how the hull reacts to the prop changes you may pick up some speed with Gills. If the Gills are in good shape selling them would put you half way to a nice low boost Pro Charger setup (dang there is that blower word again)! With that engine a 3.5 PSI Pro Charger is probably going to be the best bang for the buck. Whatever route you go do bear in mind your insurance policy. They are often somewhat void if you have done any modifications without specifically stating such to them.
BadDog is offline
Old 01-07-2005 | 07:12 AM
mcollinstn's Avatar
All Merc 502's use iron rectangle GM heads ('cept the HP525).
All BBC exhausts are steup to work with the same basic exhaust port. Some header flanges have a little different shaped hole, but they were all designed to "work" on any BBC head. If you're going for the last smidgen of HP, then you would want to match the port to the flange, but that's not the case here.
mcollinstn is offline
Old 01-07-2005 | 05:25 PM
knowledge is priceless, ...thanks guys
Old 01-09-2005 | 09:16 AM
I just had a thought.
What would happen if captndonzi bought the 500EFI cam and lifters, upgraded to roller rockers and used his Gil exhaust?
Edward R. Cozzi is offline
fastlane40
7
06-01-2008 04:55 AM
FAST ENOUGH
Drives and Lower Units
15
10-03-2007 03:41 PM
BOATING ON A BUDGET
11
02-20-2005 09:45 PM
1Boatnut
19
01-23-2003 04:14 PM
blue thunder
6
05-20-2002 08:50 AM
