How much HP can "new" Bravo's >
Old 01-13-2005 | 05:27 AM
Scott B's Avatar
Re: How much HP can "new" Bravo's
Originally Posted by cooltoys61
Higher pitched blades = flatter smack on the water when not sync'd with boat speed/rpm. Lower pitched=slice into the water easier no matter the mismatch. Add to that the more direct route of the power to the water on a high pitch as opposed to the "buffer" of more gear ratio from a small prop. Add to that the need to flog big props to get out of the hole. But hey,you can't beat the cruise speeds.
Dude, wanna put down the pipe a moment and explain that??
Scott B is offline
Old 01-13-2005 | 05:52 AM
Default Re: How much HP can "new" Bravo's
I understand Scotts logic completely, on paper. How much difference it makes is debatable and is likley offset in one way or another, by size of gear teeth and other mechanical differences.
As far as his statement envision smacking a canoe paddle into the water horizontally, now try it with the paddle at a 90 degree angle to the water.
BadDog is offline
Old 01-13-2005 | 05:53 AM
Woops, Cooltoys logic...
BadDog is offline
Old 01-25-2005 | 10:43 PM
50boat's Avatar
ive ran 750 hp on a 96 42 fountain four 4 years no down time yet,,, afrend runs 875 hp blower mots on a32 baha no down time,, 40 baha tripplehp 500 trashed --7--- drives in 14 months. ithink its the hole shot ore air time that does it. although i love to jump cruser wakes like a jetski. so how knows
50boat is offline
Old 01-26-2005 | 07:44 AM
cuda's Avatar
Scott, is this for the Critter?
cuda is offline
Old 01-26-2005 | 08:45 PM
Scott B's Avatar
X boat
Scott B is offline
Old 01-30-2005 | 08:06 AM
jaroot's Avatar
Originally Posted by Scott B
X boat
honestly scott, i could just "detune" the 16 to make you feel better
Root - die alpha die
jaroot is offline
Old 01-30-2005 | 08:46 AM
Scott B's Avatar
LOL, I'm already hearing rumours about your winter detuning project..
When do you want my SSM's for the dyno pulls BTW??
Scott B is offline
Old 02-02-2005 | 08:09 PM
Here is some info on old vs new Bravo 1's - http://go-fast.com/mercruiser_bravo_sterndrives.htm
As to the big prop vs little prop discussion above, it's all about the damage to the powertrain - powertrain being everything from the engine flywheel to the prop.
Here's the deal - powertrain damage is quantified as load^exponent times rate. In a mechianical transmission like a boat drive it's torque^exponent times rpm. The exponent used depends on the failure mode and can be either 3.33, 5.66 or 8. So, let compare a couple of way of putting 600hp through a drive. First is a warmed up 540ci belting out 600hp at 5000rpm which requires 630 ft-lbs of torque. Second is a high winding 502 producing the same 600hp but at 6000rpm would require 525 ft-lbs of torque.
OK, now let's use the lowest exponent, 3.33, and see the difference in damage between the two set-ups.
The 540 is 630^3.33*5000=1.05E13
The 502 is 525^3.00*6000=6.87E12
Therefore the lower rpm 540 would have +53% more powertrain damage than the higher rpm, lower torque 502! This change in damage relates 1:1 to the life of the drive.
Moral of the engineering story? If you want to keep you drive alive, keep the torque low and rpm up to get the power to the prop!!!
I almost forgot - this is ASSUMING the drive is sufficiently designed so the failure is in fatigue and not low cycle. Put 1000hp in front of an Alpha 1 and all bets are off!
ECeptor is offline
ls1nova
Wanted
1
06-22-2008 10:13 PM
ls1nova
Wanted
1
06-20-2008 09:27 PM
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
mikesufka
12-26-2002 11:23 AM
