O ringed block >
O ringed block
O ringed block
Old 01-20-2005 | 11:30 AM
hpy540's Avatar
Default O ringed block
Are there any disadvantages in a oringed block? I am considering purchasing one that is oringed and i am not running a blower and i am only building a NA 540 9.7 :1 with afr 315 cnc heads and a roller hydraulic cam .613 .629 112 lsa and 236 244. should i stay away?
hpy540 is offline
Old 01-20-2005 | 11:48 AM
Default Re: O ringed block
The Important Thing To Look At Is Weather The Oring Job That Is There Will Work For The Gasket Your Going To Use If Not Then You Would Have To Machine It Out The Only Gasket Fel Pro Makes With A Full Round Bore Is The Pro Stock Gasket I Think Its 17095 If Im Not Mistaking Don't Quote Me There . Otherwise You Can Use A Copper Gasket Which I Do Not Recomend For Marine Use. Good Luck Laz Mesa
MESABALANCING is offline
Old 01-20-2005 | 03:13 PM
PatriYacht's Avatar
Deck it and run a good gasket, Fel-Pro or Cometic.
PatriYacht is offline
Old 01-20-2005 | 05:52 PM
Vinny P's Avatar
I hate the winter!!
If you decided to not use the o rings and had the block decked, wouldn't decking that much material off the top of the block create problems with getting the pistons t.d.c. correct? You may have to go with a custom pin location to get the quench area right. That may also create alignment problems with the intake manifold.
Vinny P is offline
Old 01-21-2005 | 06:05 AM
PatriYacht's Avatar
It might depending on how much material is still left on the decks. I wouldn't take it past a 0 deck hgt. O-ring grooves are not very deep.
Old 01-21-2005 | 06:39 AM
You may want to check if it has already been decked then O-ringed.
BadDog is offline
Old 01-21-2005 | 09:02 AM
hpy540's Avatar
thanx and i gave up on this block it is just not worth it.
hpy540 is offline
Old 01-21-2005 | 11:09 PM
Scarab28's Avatar
Why is a copper gasket not recommended? Just wondering.
Scarab28 is offline
Old 01-21-2005 | 11:43 PM
mcollinstn's Avatar
1) salt will kill it.
2) hard to get a proper seal on the water passages, at least a proper seal that stays good. Also gotta retorque them.
mcollinstn is offline
Rockfish71
4
05-29-2008 01:39 PM
smokin' gun
Wanted
1
04-15-2008 11:27 PM
fastlane40
5
01-29-2008 06:31 AM
Dregsz
0
06-25-2005 12:26 AM
Shane
08-21-2002 01:47 PM
