Double Tie-Bars? >
Double Tie-Bars?
Double Tie-Bars?
Old 02-04-2005 | 04:42 PM
Cig35Mistress's Avatar
Default Double Tie-Bars?
Hey guys, I've noticed in some pictures on OSO that some folks are using double tie-bars, one between the drives, even with the steering rams, and one at the top of the gearcases, i.e. where a stock merCruiser bar would mount. I am running an IMCO full power hydraulic external setup on a 35' Mistress with SSMII's, and the steering cap type wing plates, what are the advantages to adding the secondary (lower) tie-bar? Thanks in advance.
Harry
Cig35Mistress is offline
Old 02-04-2005 | 04:57 PM
BajaRunner's Avatar
Default Re: Double Tie-Bars?
I would only run 1, less chance of 1 binding. people also talk about the inner and outer tie bars at the same time. you will be fine with 1.
BajaRunner is offline
mopower's Avatar
Toxic FORMULA
Unless someone can shed additional light on this subject , I think it's just unnecessary overkill.
mopower is offline
Old 02-04-2005 | 05:28 PM
InXS's Avatar
Exactly!
InXS is offline
Old 02-06-2005 | 09:05 AM
monstaaa's Avatar
dual tie bars help's to eliminate excess side load on the drives , especially in severe condition's. helps save gimbal ring's, as i learned the hard way. how ever as stated, easy to bind, and very costly if a trim button sticks.
monstaaa is offline
phughes69
Drives and Lower Units
3
09-20-2008 12:59 AM
Enforcer2
08-22-2007 01:19 PM
BZ
Fountain
10
11-15-2006 04:03 PM
superboatgmc
Superboat
2
01-07-2006 06:15 PM
wusupwchu
07-27-2005 07:09 PM
