experience with UNI-Top CMI?? >
Old 02-06-2005 | 07:12 AM
The Menace's Avatar
Default Re: experience with UNI-Top CMI??
I am currently getting pricing for a new set of CMI's. I was planning on shipping one set of my Merc's/Gil's to them for hem to copy.
What are you guys finding for lead times?
The Menace is offline
Old 02-06-2005 | 09:35 AM
iamfaster's Avatar
back to top
iamfaster is offline
Old 02-06-2005 | 02:18 PM
iamfaster's Avatar
Go Pats!!!!!!!!!!!!!!!!1
Old 02-06-2005 | 10:41 PM
Originally Posted by iamfaster
Hey griff, your boat is probable wrapped up for the winter, but would you happen to know the dimension from the crankshaft centerline UP to the CENTER of your thru-hull opening??? I measured from the center of the gimbal pivot up and measured xcross to the center of the thru-hull and I came up with 12 7/8". I was told that you neen 13 7/16" and that you need to be dead on??
Thats difficult measure with it completely assembled, at least to have 100% confidence in my measurement. It would be easy to be a 1/2 inch or more off.
I could measure it from the outside of the boat using and use the transom assembly as a reference. It would be a comparable measurement for you to check.
Griff is offline
Old 02-06-2005 | 11:06 PM
I just measured from the OUTSIDE transom assembly.
The CENTER of the tips is 3 3/8 inches above the top of the Bravo transom assembly. The tip CENTERS are 27 3/4 inches apart.
Also, if you are measuring from the crank center line, if you are slightly out of vertical alignment, that could also change your measurement.
Griff is offline
Old 02-07-2005 | 09:25 AM
jrz
The CMI Unitop water dump is as far back as the standard Bravo tail.
jrz is offline
Old 02-07-2005 | 12:17 PM
iamfaster did you figure out if the uni tops would work ??
fountain333 is offline
Old 02-07-2005 | 01:26 PM
iamfaster's Avatar
will let you know shortly...been on the phone all day with cmi....doesnt look like they will fit.
talk soon
Old 02-07-2005 | 01:27 PM
iamfaster's Avatar
fountain333, do u need both sets??
Old 02-07-2005 | 02:12 PM
no i just need one set ! call me if you want 734-819-0474
