Help, need tailpipes for triple engine setup >
Old 02-17-2005 | 06:36 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Help, need tailpipes for triple engine setup
I need tailpipes for the front engine in this Cigarette. The motors that were in the boat were 575's and I have the tailpipes that came with the boat. I put 600 efi Innovations w/ CMI headers and the tailpipes won't work. They are three inches short. Is my only choice to have CMI custom make some tailpipes? Also, used dry exhaust on rear motors. What do you think?
Mat
910-330-1911
mcraymond3 is offline
Old 02-17-2005 | 08:34 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Default Re: Help, need tailpipes for triple engine setup
If The Pipes You Have Will Work If You Only Extend The Back Of The Pipe 3" I Think I Can Get Them Extended For You. Why Would The Exhaust Change ? The Blocks Are The Same Dimensions Unless You Went To Tall A Deck. Is The Motor Bolted In The Same Location?
WILDTHING TAZ is offline
26scarab
Outerlimits
3
05-11-2006 10:38 PM
Sean
09-28-2005 02:42 PM
Wally
12-06-2003 04:52 PM
SinkorSwim
Sutphen
1
08-16-2003 06:05 PM
