Cleaning electrical connections. >
Old 02-18-2005 | 05:17 PM
R-Don's Avatar
Default Cleaning electrical connections.
Hi,
I am having some problems with electrical leakdown on my boat.
I have traced the circuit that i believe to be the problem and have come across some dodgy looking block connectors behind the dashboard.
Whats the best way of cleaning the connectors up and what can i put on them to prevent further corrosion?
Thanks.
R-Don is offline
Old 02-18-2005 | 05:32 PM
scottc's Avatar
Default Re: Cleaning electrical connections.
radio shack has a cleaner for contacts. works great then spray with a sealer or even a clearcoat.
scottc is offline
Old 02-18-2005 | 05:41 PM
R-Don's Avatar
Thanks Scott.
Im in the UK and we dont have a radio shack. Do you remember what the product is called?
R-Don is offline
Old 02-18-2005 | 08:25 PM
RedDog382's Avatar
CRC electrical contact cleaner and then a wire brush. Dielectric or lithiun grease will protect from further corrosion. Make sure the cleaner dries well before current is applied ... is is highly volatile!
RedDog382 is offline
Old 02-19-2005 | 01:35 AM
R-Don's Avatar
Thanks RedDog.
R-Don is offline
Old 02-19-2005 | 06:11 AM
Poorsche's Avatar
Ther are two others to look at--CorrosionX and BoeShield--excellent products if you can get them. Both originally developed for aircraft industry and both have websites.
Poorsche is offline
Old 02-20-2005 | 08:15 AM
I have used brake cleaner too in a pinch when I didn't have contact cleaner.....wire brush and your good again. Ditto to the corrosion X, good stuff
happy hours is offline
MitchStellin
04-29-2007 08:38 PM
plumbers crack
3
05-30-2005 03:01 PM
Biggus
12-14-2004 06:32 PM
mikev
4
01-17-2004 08:46 PM
