Removing tab stops,Dangerous???? >
Old 03-03-2005 | 05:17 PM
Default Removing tab stops,Dangerous????
My 1990 29' Fountain with twin 454 is running close to 80. I am not getting any chine walk. No, I don't have Hyd steering but the boat is stable at this speed. When my tabs hit the plastic stop on the trim cyl. the rear tip is level with the bottom of the boat hull. The base is maybe 3/4" above the bottom. I have read some posts about picking up speed with no tabs or smaller/shorter stops. Did Reggie put these on to keep me from killing myself or is there more speed to be had if I approach the fully raised position carefully?
cooltoys61 is offline
Old 03-03-2005 | 06:04 PM
Sean H's Avatar
A to Z
Default Re: Removing tab stops,Dangerous????
first, get some hyd steering..... then start looking for more speed
Sean H is offline
Old 03-03-2005 | 06:19 PM
I'll buy another boat later that someone else has paid for the upgrade,,,it really has no slop at speed so I can't justify,,love the looks though
Old 03-03-2005 | 07:33 PM
mcollinstn's Avatar
lose the stops.
Plane off.
Pull tabs all the way up at moderate trim.
Build speed with throttle first, then use trim in small increments to air out the hull. Use good sense to determine when you don't like the feel. Bump yout tabs back down a touch and see if it settles it.
In theory, everything is faster with no tabs.
mcollinstn is offline
Old 03-03-2005 | 07:58 PM
Sean H's Avatar
A to Z
and then wait for a cable to fail or the drive to rip the wheel out of your hands.... hope you don't hurt anybody...
Sean H is offline
Old 03-03-2005 | 08:27 PM
Mbam's Avatar
Offshoreonly Advertiser
We tried it back in the early 90's , no speed change that we could see, but the handling suffered.
Mbam is offline
Old 03-03-2005 | 08:31 PM
Bingo!
leave the famous Fountain "training wheels" on the rams. I've never heard of anybody gaining anything with them out.
Rippem is offline
Old 03-03-2005 | 08:32 PM
JimV's Avatar
I removed them from my 27'. The boat wanted to chine walk at 80mph but you could drive through it. Drives nice over 90 without them.
JimV is offline
Old 03-03-2005 | 08:33 PM
JimV's Avatar
Originally Posted by Rippem
Bingo!
Now that hurt!!!
JimV is offline
Old 03-03-2005 | 08:39 PM
JimV's Avatar
Formulas don't go fast enough to need them
JimV is offline
