Reversion on 502 with Quick and Quiet plus? >
Old 03-03-2005 | 10:21 PM
Default Reversion on 502 with Quick and Quiet plus?
I'm putting together a 500 HP version 502 MPI.
Crane 168731 cam. Intake .587 Exhaust .610
Cam timing @.050 Intake duration 226 exhaust duration 236.
Card does not give LSA. I will be running CMI E tops with Corsa Quick & Quiet Plus diverters and GGB mufflers. The diverters look like they are jacketed and dump water right at the y-pipe connection.
Is this a safe combo or am I heading for trouble?
revomaniac is offline
Old 03-03-2005 | 10:40 PM
Wink Re: Reversion on 502 with Quick and Quiet plus?
Your duration numbers are mild enough as long as you make sure your LSA on the cam is a minimum of 114, I would actually opt for a 116 Lsa and the motor will idle down farther and smoother with fuel injection and your Bravo will like you better to!
Good Luck with your project motor,
Ray @ Raylar
Raylar is offline
Old 03-04-2005 | 09:37 AM
Pat McPherson's Avatar
Default Re: Reversion on 502 with Quick and Quiet plus?
I believe the HP500efi uses a cam vary similar to the 731 with a 114°LSA.
The 731 has a 112°LSA...
Patrick
Pat McPherson is offline
Michael1
07-28-2022 08:26 PM
apexer
2
06-16-2008 01:35 PM
CC247
8
07-08-2007 02:40 PM
bajadude
9
09-03-2004 07:48 AM
glassdave
3
07-26-2004 10:44 PM
