Stud Girdles >
Stud Girdles
Stud Girdles
Old 03-06-2005 | 11:53 AM
Default Re: Stud Girdles
Which HP motors did you install these on?
Back4More is offline
Old 03-06-2005 | 12:00 PM
Originally Posted by cstraub
If you are using alumimun heads that will see any constant rpm over 5000 and you are running a hyd roller set up, I highly recommend a stud girdle. Aluminum heads allow the stud to flex more so then a steel head. The can lead to unwanted valve train harmonics that can harm the engine.
Chris
NOBODY is offline
Old 03-06-2005 | 12:02 PM
mikes280's Avatar
i am running the T&Ds shaft mounts and they are good even can get them with spring oilers
mikes280 is offline
Old 03-06-2005 | 12:20 PM
KAAMA's Avatar
Mark,
My engine builder (Dave Wesseldyk of WESCO) intall the Jesel Sportsman's Series on my engines set up with hydraulic roller cams. He has used them on several engines now without any problems. He only uses the competition style Jesel's on all out racing engines or on very radical cam applications.
Also, from what I could see, Laz Mesa posted a picture showing off a couple of freshly built engines in a thread here recently showing the Jesel Sportsman's Series shaft mount rocker system that he is offering on his marine application engines.
KAAMA is offline
Old 03-06-2005 | 12:31 PM
p4-33's Avatar
They were HP500's a while ago, but not much is original anymore. They're 509ci at 9.5 CR now. I'm running Pro Topline 320 heads, custom ground cams, Morel lifters, Isky Endurance springs, Jesel rockers, Pro Systems carbs, full MSD ignitions, Aeromotive electric fuel systems. Still have Dart HP500 rect port intakes, port matched to heads.
Brian
p4-33 is offline
Old 03-06-2005 | 07:02 PM
GPM
I'm running Alum. Canfield 350's with a Hyd. roller cams.
When are these girdles an absolute necessity?
If you haven't already spent the money on good rockers, studs and guide plates, don't waste the money on stud girdles.
You probably don't need them anyway. Spend the money on shaft rockers, Summit sells Jesel for around $950, T&D are good also. They both fit under stock valve covers. The shaft rockers don't dance around on the valve stem knocking the guides out.
GPM is offline
Old 03-07-2005 | 07:49 AM
My customers have given alot of postive feedback on the Jesel SS series. If you are starting fresh, then these are not much more then if you bought rockers/girdles/studs/and plates.
Chris
cstraub is offline
Ken N
2
11-04-2007 02:15 AM
Corbs
6
06-30-2006 06:57 PM
Strip Poker 388
11
10-31-2004 09:23 AM
Zanie
5
12-13-2003 06:28 PM
BAD-HABIT
7
06-23-2002 11:02 PM
