Looking For S.s. Electrical Fittings >
Old 03-05-2005 | 04:46 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Default Looking For S.s. Electrical Fittings
DOES ANYONE KNOW WHERE TO GET STAINLESS ELECTRICAL CONNECTORS ECT. SAME STUFF MERCURY USES ON THERE GIMBEL GROUNDING CABLES. IM TIRED OF DASH GAGE WIRER EYELETS BREAKING OFF BECAUSE THERE ALUM.
WILDTHING TAZ is offline
Old 03-05-2005 | 10:17 PM
Steve H's Avatar
artselectricinc.com
Default Re: Looking For S.s. Electrical Fittings
I think you would need to go to a shop that builds multistrand cables. such as a industrial supply or aircraft.
Steve H is offline
Old 03-05-2005 | 11:31 PM
mcollinstn's Avatar
good question.
SS is not a "normal" material to use as an electrical connector cause it sucks compared to copper or aluminum (from an electron transfer standpoint).
mcollinstn is offline
Old 03-06-2005 | 02:49 PM
Ed
Crimping stainless eye terminal ends, #14-10, which simply means an eye that slips/crimps over 14 gauge wire...with a #10 size hole in it for a #10 size gauge stud...is asking for trouble, since the wire is copper. The ideal eye end is made by "Panduit". It is silver coated. Crimp them on with a Panduit crimping tool ONLY...after you have slipped a piece of EPOXY heat shrink tubing over the wire to heat & shrink. You're problems will be over. Ed
Ed is offline
Old 03-09-2005 | 04:18 PM
B-MAX REPAIR
My Dash Gauges Have Heatshrink To The Eyelet. The Problem Is The Eyelet Breaks Off And Allyou Have Is A Washer Under The Nut And The End Of The Wirer With The Crimp On The End Of It. Vibration Over Time Is Causing This. I Also Need Stainless Eyelets To Made New Grounding Wirers For Transom Assem. We Rebuild Gimbel Rings & Bell Housings. People Need 1 Or 2 Grounding Wires Not Mercury's Whole Kit. And My Stuff Would Be A Whole Lot Cheaper. Ill Try Looking Into Aircraft. Rb
Old 03-10-2005 | 01:23 PM
Mr Gadgets's Avatar
Charter Member #601
TAZ,
Take a look at this site once, maybe they can help you?
http://www.amgndsys.com/
Mr Gadgets is offline
Old 03-10-2005 | 05:41 PM
B-MAX REPAIR
Ill Call Them Tomorrow It Looks Like It Might Be The One Thanks. Ron Bender
OPA
Wanted
1
07-23-2008 09:58 AM
Ken N
3
12-26-2007 08:44 AM
Stormrider
1
04-12-2005 10:31 AM
cooltoys61
1
04-19-2004 08:27 PM
