Motor to come out. What to check? >
Old 03-07-2005 | 09:55 AM
BillR's Avatar
OSO Moderator
One of my 575's has to come out because my tech believes a tooth on the flywheel is damaged/broken.
What else would you check while the motor is out and access is unlimited? (motors have 219 hours)
Here are my thoughts:
New plugs
Check coupler
New PVC valve
Check for corrosion - refinish as necessary
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 03-07-2005 | 10:28 AM
Biggus's Avatar
Default Re: Motor to come out. What to check?
Install new bilge pumps. Even if yours is working fine, most cases the motor needs to be pulled to gain access.
Bill, you are a MADMAN!!!
Kurt
Biggus is offline
Old 03-07-2005 | 10:53 AM
Gizmo's Avatar
Are we having fun, yet?
Bill, Consider replacing the raw water pumps while the engine is out. A lot easier access. I did an engine pull for Lowrider a while back for the same reason. I replaced anything that was difficult to get to with the engine in the hull.
Jay
Gizmo is offline
Old 03-07-2005 | 02:25 PM
Croozin2's Avatar
Lower shift cable on Bravo drives, Check water passages in transom assy. It is a rubber hose that has a ferrule on the end and depending on the age and if it is a salt water boat the passage will actually corrode and squeeze off the water supply to the sea water pump. Much easier to check while the engine is out.
Croozin2 is offline
Old 03-07-2005 | 04:07 PM
Snug up the oil pan bolts. Both engines. Check torque on harmonic balancer bolts, both if you can reach it.
BadDog is offline
Old 03-07-2005 | 07:06 PM
baja36ft's Avatar
Hey Bill, If You Need Any Help Give Me A Call!!!!!!
I Would Send The Starters Out To Be Rebuilt
Stan
baja36ft is offline
Old 03-07-2005 | 11:42 PM
Strip Poker 388's Avatar
Rob
Why did the flywheel go out . Ck starter tooth depth.
The oil pans bolts is a good idea
Strip Poker 388 is offline
Old 03-08-2005 | 07:43 AM
BillR's Avatar
OSO Moderator
Not sure. "I" thought I had a starter problem. (Tech didn't) I had a new starter installed. While turning over it gets to a spot and makes a noise and stops. Try to turn over again - same issue. New starter made problem worse, but that is probably because tech didn't install starter shim on new starter.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
JRider
18
08-28-2008 12:49 PM
racer-x6
03-20-2005 08:32 PM
502procharger
06-24-2003 12:10 PM
