Chine Walk and Prop Effects? >
Old 03-09-2005 | 12:12 PM
Default Chine Walk and Prop Effects?
Was talking to the mfg of my 30' triple steped V hull twin (turning in) about the severe chine walk we experience above 70 and he stated the problem was a lack of "matched" props. He maintained that the variance in the Bravo 1 factory props was enough to cause this condition. We are not talking Labbing the props, just making them the same.
THis doesn't sound right. Any comments? I would like to be as informed as I can when I talk to him again.
LHC30Victory is offline
Old 03-09-2005 | 12:26 PM
Whiteknuckle's Avatar
Default Re: Chine Walk and Prop Effects?
Is this a new boat that was delivered from the dealer with these props? How do the props compare? Are they identical from the factory, or is one a Mirage and the other Mirage Plus? I'm not buying into props on a 30ft chine walker at just 70 MPH. Something is wrong unless you are trimming out way to much. Need more info!
Whiteknuckle is offline
Old 03-09-2005 | 12:41 PM
Yes, these are both Bravo 28p 4Blades that were on the boat when new. Have had this prob since new and no, trimming out is not the problem necessarily. I have adjusted the trim many times and the problem still exists at speed unless I trim it down so far that it starts to Bow Steer (BAD!).
Old 03-09-2005 | 12:49 PM
throttleup's Avatar
Can you give us a little more information.
year, make and model of boat.
engine specs.( HP and Peak HP RPM)
drive type and ratio
WOT RPM and MPH (gps)
Julie
throttleup is offline
Old 03-09-2005 | 12:50 PM
I would start by switching the props and turning them out.
What kind of boat???? Maybe someone else with the same model will chime in.
Griff is offline
Old 03-09-2005 | 01:25 PM
I purposely kept Advantage out of this because they are working with me, I just think their info is wrong but am open to learning. That being said...
2004 Advantage Victory ( open bow); twin 496ho's w/ 1.5 b1X drives; I don't think I have ever gotten true WOT cause of the walk but at 4800-4900 I have gps of 77.8. Have tried the props out but this boat seems to need the bow lift of turning them inward. in either case, it walks.
Have spoken to one other owner of a similar boat (seen in Powerboat) and he said tabs were his only answer to the walking.
Old 03-09-2005 | 01:46 PM
Do you have tabs on the boat now?
Dangerous Dave is offline
Old 03-09-2005 | 01:58 PM
No, that's where I'm heading but honestly want to try full hydraulic steering first. I have the Hyd assist now.
Old 03-09-2005 | 02:00 PM
Sorry I misread. I read Bravo's and was thinking Mirage
You might want to consider doing both
