Kpm Racing Raw Water Impeller >
Old 06-26-2005 | 10:40 AM
  #41
Mr Gadgets's Avatar
Charter Member #601
Default Re: Kpm Racing Raw Water Impeller
Fred,
The pump was there when I returned from boating on Friday.. Took a good look at it today during breakfast.. LOL! What a beautiful piece..
One thing.. I tried to screw in the two 90* fittings.. it was a no go.. holes are too close togther... I have some ideas. I will give you a call on Monday..
Dick
Mr Gadgets is offline
Old 06-26-2005 | 05:09 PM
  #42
Mr Gadgets's Avatar
Charter Member #601
Yes.. shorter ones will work. I thought about cutting these, but then you loose the ridge that helps hold the hose..
I am thinking the fittings that Wette Vette has on the back of his.. If I had one of those I could screw one in and bolt the other on. They would be offset a bit but who cares.. it has enough beauty to carry, we just need the functional part...
Dick
Old 06-27-2005 | 04:31 PM
  #43
Mr Gadgets's Avatar
Charter Member #601
Hey Thanks Fred!! I will check it and send back the others..
Dick
Old 06-29-2005 | 12:02 PM
  #44
StrikinLightnin's Avatar
p4-33
Bolted up the frount motor mount and found that I'll
have to do a little air-arc on the mount in order for
the hoses to fit.
No big deal.............
StrikinLightnin is offline
Old 07-05-2005 | 10:21 PM
  #45
klmken's Avatar
Fred,
I just received my pump and forgot the fittings. What are the dimensions thread and diameter?
Ken
klmken is offline
Old 02-08-2006 | 09:44 AM
  #46
boatman22's Avatar
Some good info here. I am waiting for 2 kits from Fred. My motors are out so it should be fairly painless to replace. I will try to post pics when I get them.
boatman22 is offline
Old 02-08-2006 | 10:49 AM
  #47
Wobble's Avatar
SORE MEMBER
Fred (Trick), whats up with all the deleted posts?
Wobble is offline
Old 02-09-2006 | 09:44 AM
  #48
Scarab3DMC's Avatar
AAAAAA... MR. Cecil....I still need to talk to you about that swim ladder and the rest of my order... cell= 216-406-0368... Dave... I know your busy in Miami..
Scarab3DMC is offline
Old 02-18-2006 | 01:13 PM
  #49
boatman22's Avatar
Ok here goes: received my 2 kits yesterday and I’m trying to install today. I can’t figure out how to mount the pump to the bracket. If I take the backing plate off there are holes all the way thru but you can’t put bolt thru.
My question is, looking at the photos from StrikinLightnin
http://www.offshoreonly.com/forums/s...m+pump+install
Post 18
Do I need to drill thru the backing plate?
I have marked with arrows.
It just seems that I should not have to modify the pump or anything for that matter.
Old 02-19-2006 | 10:24 AM
  #50
boatman22's Avatar
Well after trying to figure this out for the better part of the morning yester, I decided to drill new holes in the pump housing. I wish KPM would have a direct kit to replace the plastic housing instead of going with universal type housing. Below you can see the holes that need to be drilled. I used SS cap bolts as I could not find SS Allen head in 3 ½”
Attached Thumbnails Kpm Racing Raw Water Impeller-dsc00218_resize.jpg   Kpm Racing Raw Water Impeller-dsc00219_resize.jpg
