Alpha 1 Prop Selection (Need Help) >
Old 03-18-2005 | 07:58 AM
BRIAN73's Avatar
Default Alpha 1 Prop Selection (Need Help)
Hello everyone,
I have a friend who has a 21 ft donzi minx with an alpha 1 hooked up to a 350 making around 360hp.
We are trying to come up with different prop combinations.
He has run a mirage, mirage+, 3blade quicksilver cleaver and a
a stiletto.
My question is, are there any other prop designs that would give alot of bow lift. I was thinking of 3 blade chopper, but I wasn't sure how it would work on a alpha case. What about a four blade design.
Any help from the guru's on this site would be a great help.
Brian
BRIAN73 is offline
Old 03-18-2005 | 09:51 AM
Thumbs up Re: Alpha 1 Prop Selection (Need Help)
Bow lift = Bravo 1 props but first call Julie or Matt at Throttle Up 877-842-6855 and they will work with you. They dialed me in with a bravo 1 and now I'm upping my HP and may be changing gear ratio in the alpha. Good luck.
Badtoon is offline
Old 03-18-2005 | 11:26 AM
throttleup's Avatar
Default Re: Alpha 1 Prop Selection (Need Help)
Give us some details about the set-up and we will try to get you dialed in.
What power?
What Drive and gear ratio?
With each prop what is the WOT RPM and MPH (gps)?
Tell me a little about the attitude of the boat with each of the props you listed.
Julie
throttleup is offline
Old 03-18-2005 | 11:59 AM
BRIAN73's Avatar
Julie,
I will get all the info from my friend and call you on Monday.
Thank You
Brian
BRIAN73 is offline
Old 03-20-2005 | 12:38 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Brian73,
I had a 454/alpha 1 86 nova 23. Engine mods were slight: cmi headers, edelbrock, holly 810 shotgun silencers, with mild crane cam slight cylinder head clean up-5.2k rpm range. Had all the following props in the garage Quicksilver Lazer; cleaver; mirage and hydromotive all 3 blade reworked 21's. I believe the drive had a 1:36 ratio (original for 86-87 year).
Best of the bunch for my application was the lazer for top end very poor off the line w/ much cavitation upon standing start and tight turns, overall I used the hydromotive for all activities, but the lazer kept the nose up and loved the mid-range to top end punch. Just my .02. - Good luck
GoCiggie31 is offline
johnsc91
Prop Talk
27
05-04-2020 08:41 PM
speedboatr
Prop Talk
3
08-31-2006 06:22 AM
RACER8
Skater
2
07-21-2004 03:31 PM
RACER8
1
07-19-2004 11:37 AM
patrick22309
01-14-2003 11:54 AM
