Power Steering >
Power Steering
Power Steering
Old 03-23-2005 | 11:08 PM
Default Power Steering
converting a 496HO to external steering. (MarineMachine) Single ram, using the stock Merc p/s pump: I have blown the seals on two rams: What is the max pressure the rams can take: "hard over" I've got about 700 lbs on the prssure side. I've installed a pressure regular/gauge so I can now adjust the pressure. It seems to work very well at about 500 lbs. Any thougths? This is on a commercial parasail boat, w/ Bravo II
stevehaolecrab is offline
Old 03-24-2005 | 07:49 AM
Stormrider's Avatar
JC Performance Engines
Default Re: Power Steering
How bout going w/ dual rams.
Stormrider is offline
Old 03-24-2005 | 07:56 AM
Dave M's Avatar
Veteran: Navy
I have a Marine Machine single ram system and a 496HO. I only have a few hours on this setup but no problems so far. Do you have full hydraulic or add-on?
Dave M is offline
Old 03-24-2005 | 11:53 AM
System is a full system: helm, p/s pump, filter (Latham) all plumbed directly to the single M/M cylinder. It's just a single cylinder system. The main reason for going this route is we destroy parts because of the play in the stock steering/gimbal housing set up. Gimbal rings, pins, bushings, steering lever all wear because the constant "thrashing" the drive takes. These boats are on the water 2500-3000 hours a year!
Old 03-24-2005 | 09:02 PM
monstaaa's Avatar
some times the fitting in the back of the pump that the pressure line screws into has to large of a diameter( twin engine pump) which in turn allows the pump to put out more pressure as well as volume.
monstaaa is offline
Dtile
3
12-24-2006 11:47 AM
electrical1
6
06-11-2006 08:29 PM
florida gator
1
04-13-2003 06:57 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
waden54
2
06-30-2002 08:23 PM
