Press Relief Valve Part #
I like to see around 20 psi.
With the Merc valve in my setup, when the valve opens, it pulses water out about six feet out the dump! And this is a 1" hose and dump!
But, it's pulsing out, instead of a steady stream, so maybe the 1/2" will be enough.
Let's all hope that part works!!
I think you would need 2 of those if using a crossover and no circulation pump. I used a similar valve from McMaster Carr and wound up with two in the system. One is set a slightly higher pressure than the other. Sort of balance so one is full open at 10 PSI and then the other one start opening at 15 or so. This results in pressures of 5 at idle and steadily builds to about 18 at 3000 rpm and may see 19 at WOT. Just have to balance them. I ported both 1/2 to a 3/4 dump aimed at the top cap of the Bravo.
Originally Posted by Mudball
Possibly, but how would you calibrate it?
I am hoping there will be an adjustable version soon. It is aftermarket. Not made by me, but I will be helping to test it on the water.
Kent
Kent
The valve in the CPPerformance link is what I tried. It is a Watts brand valve. I bought mine from Teague for a mere $100 with a fitting a few yrs ago. All these dealers use the same Watts valve, then mark up the price at unbelievable prices. Mine was the 1/2" and no where big enough. Even at full open, it still would not dump enough water to lower my pressure. A 3/4" min. will be needed. I seen these same valves for $20-30??
Links to valves at Grainger. I'm sure they are available elsewhere.
Here is a link to 1" valves I used.
http://www.grainger.com/Grainger/pro...543226&ccitem=
Here is a link to a 3/4" valve that I have seen used.
http://www.grainger.com/Grainger/pro...543225&ccitem=
