Compression change >
Compression change
Compression change
Old 03-27-2005 | 12:21 PM
ROADHOG's Avatar
Default Compression change
When changing compression from 8.75 to 9.5 of 9.75 what should a person see in the difference of HP? Base motor is 500EFI. Is there a rule of thumb as to how much HP gain per .25 increments?
ROADHOG is offline
Old 03-27-2005 | 05:03 PM
excursion's Avatar
Default Re: Compression change
I just did that too my motors over the winter and took them to 9.75 comp. , everyone said I should have with the other mods done, cam, porting, carb.....should be around 580-590hp.
excursion is offline
Old 03-27-2005 | 07:33 PM
mcollinstn's Avatar
usually a longer duration cam accompanies a hike in compression ratio.
Some combinations could actually lose power with a hike, if you were running close tooptimal cylinder pressures already.
mcollinstn is offline
Old 03-27-2005 | 08:16 PM
Hot Rodding did a article awhile back that started at 8to1 up to 12to1 averaged about 4-5%increse per increase. Of couse
cam, heads and other factions will come in to play.
Bad to the bone is offline
ENFORCER24
8
05-14-2007 07:26 AM
375stinger
2
11-23-2005 08:58 AM
BOATING ON A BUDGET
4
02-14-2005 09:31 PM
Pure Energy
5
07-28-2004 10:47 PM
Tejas Raz
2
06-26-2003 09:53 AM
