quad-rotor 565 >
quad-rotor 565
quad-rotor 565
Old 03-30-2005 | 07:34 PM
  #61
44MTI's Avatar
Default Re: quad-rotor 565
Originally Posted by zt260
Breaking the dyno. LOL
My engine builder said the same thing. Thats why we never pushed past 1370HP
I adjust my afr in the boat via the EFI computer. This is one of the big advantages for EFI
I'm running 34*, 12.5 afr, 15# boost, 112 octane.
Sounds like it's time to test you engine in the boat.
I don't know what I'm going to do about the trannys???????
44MTI is offline
Old 03-30-2005 | 07:40 PM
  #62
zt260's Avatar
Now your out of my area, I'm running Bmax drives. But there are plenty of people here to help. Ring in guys...
Or you can start a thread on trannys for big power.
zt260 is offline
Old 03-30-2005 | 07:49 PM
  #63
44MTI's Avatar
So how do the Bmaxs handle it, and how do you drive it.
44MTI is offline
Old 03-30-2005 | 07:58 PM
  #64
GPM
Originally Posted by 42MTI
Just got another dyno update, we have not hed all the pullies needed. Today they got 1340hp with race fuel, I don't know how much boost. They are stil running 32* timing and A/F is stil 11.4. They want to lean it out but it is breaking the dyno. Torque won't allow them to pull much below 6000rpms. They feel like it would make over 1400 with 36-38* of timing and better A/R numbers.
GPM. I know what you are saying, these are from a very conservative shop and engine builder.Teague built some 565ci carb motors with AFR heads that make 1435hp. and Sterling make some 557ci EFI with Big Cheif heads that make 1530 hp and had a little more if they wanted to lean on them.
I've heard the big numbers, and I'm not saying they're not true, I just haven't seen any proof. I would like to know what the combo's are, what boost, and can they be run in the real world.
GPM is offline
Old 03-30-2005 | 08:06 PM
  #65
44MTI's Avatar
I agree, I was concerned while writing the check, very concerned.
However mine are real numbers, Boyd's dyno #'s are usually about 40-50 hp than other comparables, but tend to run faster.What sold me was Merc swithching and picking up 175hp on basically the same motor, and now Sterling with several big HP packages.
44MTI is offline
Old 03-30-2005 | 08:27 PM
  #66
GPM
42, I believe your numbers, I've seen similar on my dyno sheets. All blowers rob horsepower, I've heard as much as 400 hp, when you take this into consideration how many horsepower is it really making to see 1500 on the dyno. I would like to hear about these combo's. I'm always looking to upgrade. Just curious, what do you think about the BB3's ?
GPM is offline
Old 03-30-2005 | 08:36 PM
  #67
44MTI's Avatar
I've given most of my combo.Carbs are 1050 holly, 3.3 quadrotor, with moac intercoolers, brodix 3x cnc. cams are from Gary Teague,by recommendation from Dustin,approx. .775 lift. Motors made peak hp yesterday at 6700 don't know about today.
I think we talked about the heads a while back, don't you run Brodix also. My engine builder said they flowed very well, better then the Dart cnc which was my second choice, However getting shaft rockers was a slow aggravating process.
44MTI is offline
Old 03-30-2005 | 08:46 PM
  #68
GPM
We did talk a while back, and yes I do run the Brodix heads, I tried the BB2 extra and the Big Dukes. I think you're making good power, it's more than what's usually posted on here. I wasn't questioning your combo, sounds like you're going to be running pretty good this year.
GPM is offline
Old 03-30-2005 | 09:07 PM
  #69
....cams are from Gary Teague,by recommendation from Dustin,approx. .775 lift. Motors made peak hp yesterday at 6700 don't know about today.
Might I ask what you paid for them? I have a feeling I am about to be sick
RichardCranium572 is offline
Old 03-30-2005 | 09:09 PM
  #70
zt260's Avatar
I don't baby it. The bmax has held up pretty good. I broke a gear in the lower, but thats it. I can live with one broken gear every year or two.
Especially when its under 3 year warranty.
zt260 is offline
