Is This Cam To Big? >
Is This Cam To Big?
Is This Cam To Big?
Old 03-30-2005 | 06:53 AM
Default Is This Cam To Big?
I rebuilt my 330HP last year. Tried for 9:1 compression. Added a fresh set of 781 large oval port heads, Edlebrock carb and intake. Cam listed below. IMCO Power Flow Exhaust. Gained absolutely no additional RPM. I checked compression before I pulled the engine last fall, 150 PSI on all cylinders. That did not sound very high to me so I thought about the cam. I talked to Dennis Moore and he said that should be a good choice. In his book he states this is the largest cam that should be used in a marine engine. What gives? To big for my little combo?
COMP 11-242-3
Gross lift 515 520
Duration at .050 224intake 230 exhaust
Lobe Separation 110
I degreed cam ia at 106 center line like suggested.
New valve springs with valve job
1BIGJIM is offline
Old 03-30-2005 | 12:53 PM
Default Re: Is This Cam To Big?
Any comments from any of you cam experts
1BIGJIM is offline
Old 03-30-2005 | 01:26 PM
Needs more cam and more cylinder head The changes you made are not much above stock, truly need to check AFR as it could be going rich on the top end reducing power too.
RichardCranium572 is offline
Old 03-30-2005 | 01:39 PM
PatriYacht's Avatar
What rpm did it used to run? What kind of boat is it in? It should be a torque engine but it will be all over by 5000 rpm.
PatriYacht is offline
Old 03-30-2005 | 03:05 PM
It ran 4900 to 5000 RPM. Boat is a 22' Pachanga
1BIGJIM is offline
Old 03-30-2005 | 03:36 PM
PatriYacht's Avatar
You can always try more propellor and see if it'll pull it. I would expect it to be a little faster.
Old 03-30-2005 | 05:21 PM
Vinny P's Avatar
I hate the winter!!
I would not have picked that cam soley for the lobe seperation. 110* is too tight for wet exhausts. Too much of a chance of reversion. 150 psi is a good compression number for that combo. I am sure you are losing compression with the small lobe seperation.
Vinny P is offline
BajaRunner
13
02-07-2014 08:32 AM
jeff1000man
5
07-23-2007 11:13 AM
1BIGJIM
13
06-12-2005 06:47 PM
Pat McPherson
12
08-14-2003 11:06 AM
