Anybody have Coupler Problems? >
Old 04-04-2005 | 09:19 AM
tiufb's Avatar
Default Anybody have Coupler Problems?
I hear a lot about people breaking drives (I have too), but this weekend I blew a coupler. The boat was not sitting up all winter, sorry you northern guys. I was just wondering how many of you have had this problem. Thanks for the input.
tiufb is offline
Old 04-04-2005 | 09:54 AM
fund razor's Avatar
Default Re: Anybody have Coupler Problems?
I caught a bad one (wear) after I bought my boat.
The teeth were sharp instead of square.
Went with the stock replacement. (I am only 260 hp/side)
fund razor is offline
Old 04-04-2005 | 11:18 AM
I've gone through a couple, no pun intended . Could be due to engine/drive alignment, high HP, or maybe bad gimble bearing.
Pure Energy is offline
Old 04-04-2005 | 11:31 AM
fund razor's Avatar
Mine was due to bad alignment from the previous owner.
Old 04-04-2005 | 11:54 AM
madbouyz's Avatar
Mine was due to bad alignment from the (ex) engine installer
madbouyz is offline
Old 04-04-2005 | 12:05 PM
rouxsterre's Avatar
Mine was due to the previous owner NOT EVER charging the grease fittings.
rouxsterre is offline
Old 04-04-2005 | 12:18 PM
BLee's Avatar
Charter Mod
I'll put this in the Technical Q&A section. Alot of folks lurk that section and could offer some assistance.
BLee is offline
Old 04-04-2005 | 02:16 PM
zahndok is offline
Old 04-04-2005 | 02:20 PM
A Bravo coupler failure? Unheard of!!!!! Just kidding, probably #3 behind blown uppers and loose gimbal rings.
Very common, keep engine aligned and grease it and it will last somewhat longer.
Gary
Gary Anderson is offline
Old 04-04-2005 | 02:28 PM
carney's Avatar
I agree with gary, If you pull the drive once a year check alinment, grease the shaft , change the drive oil your problems will be far and few.
carney is offline
