Dyno vs Actual Exhaust >
Old 04-14-2005 | 04:32 PM
  #51
Default Re: Dyno vs Actual Exhaust
Your hitting the torque plateau of the engine for the way it is cammed. I preach small cams but what you have is very little for what you want to do. Something in the 220ish @ .050" range should get you the R's you want to turn.
Now the truest test for any engine is when she comes off the dyno with numbers and those numbers are verified when put in the boat, car, truck, whatever. You may want to go to another shop for a 2nd oppinion.
Chris
cstraub is offline
Old 04-15-2005 | 08:14 AM
  #52
Good point Chris! Not all dyno calibrations are created equal. Also if the 24 Pantera really does 90 with 600 ish HP I would be very inpressed with the efficiency of the hull. There are comparable sized cats that won't run that good with 600.
WETTE VETTE is offline
Old 04-15-2005 | 08:37 AM
  #53
GEOO's Avatar
1975 X-18 Donzi, Arneson
You should change the piping from the IC to your Intake. You'll Gain 2 mph!! If you switch to a 504IC you'll gain 4-6 mph. I swiched from a 324IC with piping like yours to 504IC and cleaned up the piping and gained 170hp (on a custom small block with a M3 Procharger) same dyno same day no other changes but needed to increase fuel pressure. Look at the picture of my freinds 454 with the 504 IC much cleaner and less restrictive then the 324IC set up.
GEOO is offline
Old 04-16-2005 | 12:12 AM
  #54
articfriends's Avatar
I'm running the aw504 innercooler,i offset it on helm side of motor,their was not enough room between back seat. I did some pressure drop testing in the fall and with my elbows i'm loosing less than 1.5 psi from innercooler and piping,Smitty
Attached Thumbnails Dyno vs Actual Exhaust-picture-2-010.jpg   Dyno vs Actual Exhaust-boat-tests-014.jpg
articfriends is offline
Old 04-16-2005 | 08:47 AM
  #55
Hang Time 27's Avatar
My 24 excalibur, which is about the same dimensions, ran about 80 with less than 500hp, so it wouldn't surprise me. I'm not so sure hull efficiency has as much to do with it as drive height, because there is only about a foot or two of the hull in the water at that speed....................The Ex did have a 4" pad it would ride on though...................
Hang Time 27 is offline
Old 04-17-2005 | 08:45 PM
  #56
Elite Marine's Avatar
Thanks for the input...great answers and alot of good ideas.
I just pulled the boat out of storage, so I'll look into the pulleys and belt.
Smitty -
I'm going to have my guys fabricate a new supply manifold from the intercooler to the intake manifold from polished OD/ID SS tube, hope to eliminate soem of the drop and get beeter flow with the smooth ss and orbitally welded joints.
Elite Marine is offline
Old 04-19-2005 | 10:30 AM
  #57
razor1115's Avatar
Sorry if this seems too simple... are the butterflys on the carbs opeening all the way? Possible that the throttle cable is not adjusted correctly to allow for max travel?
Zack
razor1115 is offline
Old 04-19-2005 | 09:20 PM
  #58
They open all the way. Good idea though, it's happened to many people.
Old 05-22-2005 | 07:27 PM
  #59
Here's where I am in my 28.
24P Bravo 1 Prop.
4000 RPM - 50 MPH
5000 RPM - 63 MPH
I have adjusted fuel pressure up and down, minimal effect.
I think a new cam is in order. What are you guys running? I have a 502 Intake and I'm going to get 50 PSI injectors and have the ECU reprogrammed. Now I need a cam...
Old 05-24-2005 | 06:08 PM
  #60
Its between the Crane cams below:
731 : 226/234 .587/.610" lift
741 : 234/242 .610/.632" lift
How do I know if my spirngs are up to the challenge?
I run ISKY 9265 Springs.
Hopefully a cam change, injector change and a reprogramming will get me through the year . . . . . . . . . . then I'll build a 540 short deck for next year, close to 900 HP.
mv35
Swap Shop
1
08-06-2008 10:33 AM
unbroken
2
06-09-2007 09:12 AM
ECeptor
1
10-20-2005 10:07 AM
bob
5
03-21-2003 03:20 PM
kook
Sunsation
1
01-08-2002 07:20 PM
