LOTO Shootout 2012
Old 08-20-2012 | 08:37 PM
  #41
To the best of my knowledge, the ramp and parking area at PB2 is open at night. The store is closed after around 5 pm or so. You might call and check if you can find a phone number. I do not know the parking situation at Summerset but I suspect it would be tight. You might call on that and some of the other guys on here might know about that. The trailer parking at PB2 is just so easy.
E Dock DD is offline
Old 08-21-2012 | 07:53 AM
  #42
You are correct. I called a water po-po friend of mine from there and gates are open all night. thanks for the help. See you guys there...
keegan is offline
Old 08-21-2012 | 12:58 PM
  #43
Does Camden have a ramp?
waterboy222 is offline
Old 08-21-2012 | 02:32 PM
  #44
delete
keegan is offline
Old 08-21-2012 | 03:00 PM
  #45
Nope. U have to go down the road to Glencove Marina.
rynobranch is offline
Old 08-21-2012 | 04:05 PM
  #46
Quinlan's Avatar
U commin up to play man?
Quinlan is offline
Old 08-22-2012 | 09:24 AM
  #47
Mapquest says its 10 miles away?! Is there nothing closer?
Old 08-22-2012 | 06:39 PM
  #48
Keytime's Avatar
Wrong Glencove location, I'm thinking. Here it is (6 miles, although I used Shady Gators next door as a start):
http://maps.google.com/maps?saddr=Sh...=h&mra=ls&z=14
Hard to believe that Horseshoe Bend doesn't have a public access launch, but I don't believe they do. I usually use Bergers at the 1mm, but you'd probably be better off using Glencove unless there's another out there I'm not aware of. Glencove shuts their gate at closing hours or so, so you might wanna call ahead if it's getting around that time.
Keytime is offline
