Go Back  Offshoreonly.com > Owners Forum > Kryptonite
The new project >
The new project
The new project
Old 12-31-2009 | 10:33 AM
  #51
Originally Posted by Jmemoli
As far as speeds , this boat weighs in at around 4200 lbs wet -
500 EFI ran 81 mph
540 ci /600 hp ran 87 mph (never dynod )
The labbed 4 blade hydro is the best prop to run on this boat -the boat needs a little transom lift to air out the step - too much lift and yes it will walk -
Really depends on what you are doing with the boat - to fly off 4-6 footers at 75 mph , the hydro keeps her flying level with less ballast up front .
I had a 5 blade Hydro and it walked bad, I put on a bravo 1,and it is much better. Did you compare the bravo 1 to the Hydro? Also who did your prop work? With my new motor I will be needing a new prop and if i could benefit from your knowledge that would be appreciated
thanks
DonRoc is offline
Old 12-31-2009 | 10:42 AM
  #52
By the way , after running 2 mag 27s , and 2 Pantera 28s , this boat by far is the best in the rough , fastest with least hp, and well balanced 27 i ever drove and raced .
That's what I like to hear
jdub is offline
Old 12-31-2009 | 10:45 AM
  #53
Well get used to hearing it, because it seems that everyone who has owned/driven one says the same thing.
Philm is offline
Old 12-31-2009 | 10:57 AM
  #54
TeamSaris's Avatar
Driver-441
Racer
Can i have my boat back ?
Hahaha wait till you see the old girl, ballast tank, flat black dashboards, black rubrail, diferent hatch...were gonna suprise some people this year
TeamSaris is offline
Old 12-31-2009 | 11:20 AM
  #55
Jmemoli's Avatar
Goumada P5-38
Johhny,
Hope you and your dad kick some serious #ass#.
The boat ran ok with a 24 B1 stock , ad a 26 B1 stock also .
Randy Schleuss from Typhoon turned me to the hydro 4 blade . Throttle up labbed them - they also turned down the OD by 1/2" . the hydro loosened up the boat a little , with little or no chine walk at top speed - chine walk is loose, loose is fast , nice !
To keep the boats under 75 (which is hard to do ) , we ran 23 or 24 pitch hydros cut down -
I ran one of Randys 27 " Hydros , labbed from TU.
Incredible acceleration from bottom to top, ran 86 to 87 mph at around 5700 as i remember . Randy swears by them -
The Krypto hull is very efficient up top , and you dont need much blade surface to get the speed - te smaller blade surface acts like a higher stall converter also for engines with less torque and high RPM.
The 5 blades give too much transom lift - never used em, never liked em - some boats love them -
Jmemoli is offline
Old 12-31-2009 | 04:02 PM
  #56
Johhny,
Thanks for the info
DonRoc is offline
Old 12-31-2009 | 04:50 PM
  #57
TeamSaris's Avatar
Driver-441
Racer
Johhny,
Our goal is to make the boat accelorate like a mofo, and run out of steam around 75-77. 575 hp but 65o lbs of torque is the goal
Old 01-13-2010 | 02:23 PM
  #58
TeamSaris's Avatar
Driver-441
Racer
Motor is starting to come together a little bit...still some glass work left to do on the boat...Ill have pics soon
Old 01-14-2010 | 03:55 PM
  #59
Looking good....keep posting progress pics.
Back4More is offline
Old 01-14-2010 | 03:59 PM
  #60
TeamSaris's Avatar
Driver-441
Racer
Dads got me too busy doing other ****
