X-Dimension/Pad
Jdubs full vee is definitely a smoother ride than mine with a pad. I dont think it is the driver but you never know. Of course it isnt as fast as the pad bottoms...
I usually ran the boat with just a touch of tab and the drive just past neutral. I saw 85 mph with 550-570 hp. Iwas going to play with spacers if I kept the boat. Mine was the first one built with the extension box.
A little tab to settle the boat shouldnt be a problem.
Exactly! The tabs added that little extra length that really planted the boat and made it run level. It was very light in the nose and tended to ride nose up and slap if you didn't drag the tabs slightly.
This is a hard one. Both of my Krpto's had a notched trans with no box on the drive. I always put weight in the front to make weight when racing in F1. For what ever reason my boats always ran fastest and best with the extra weight I had carry forward. We had to weigh 4700 lbs coming out which ment adding aprox 200-300 lbs. Now in racing thats a hugh advantage to be able to place the weight where you wanted. Everyone else that had to place weight always and I mean always put there weight in the transom for max speed. We would put it just in front of the dash and go forward from there if the water got bigger.
If you Krypto owners have noticed we have to do our set up a little differant. Taking advice from someone who has never owned a Kryto is most likely not going to help us. Its great you guy's all share all your info. Mine is only one dementioal WOT turn left.
MD
MD
