Hotlavey - got your email....thanks!!
How did the boat run with your stock power? Did the boat change for the negative after you put the Whipple on it? Thanks, Chris I read a boat review on the 2750 with the 525 package....all high marks - so just wondering if these issues you had were from more power, more torque and bigger prop??? Thanks again! |
Originally Posted by Schweeng
(Post 3090239)
How did the boat run with your stock power? Did the boat change for the negative after you put the Whipple on it? Thanks, Chris I read a boat review on the 2750 with the 525 package....all high marks - so just wondering if these issues you had were from more power, more torque and bigger prop??? Thanks again! After the first Whipple(2.3) same problem, just faster. 2nd Whipple(3.3) and a Imco shortie, not much difference- no better no worse. Bottom work solved all the problems. I should have started there first. Best investment I made with this boat. Hope this info helps, Tom |
(Post 3090239)
How did the boat run with your stock power? Did the boat change for the negative after you put the Whipple on it? Thanks, Chris I read a boat review on the 2750 with the 525 package....all high marks - so just wondering if these issues you had were from more power, more torque and bigger prop??? Thanks again! with smaller power like the 496ho it ran beautiful and most of the time would run 70-75. This is so because the hull had so much lift, it would help out and give all the added lift the smaller power needed to run fast. But then as you start adding more and more power, the boat just lifts more and more as speed increaes and at that point it becomes a boat that is classified as a "drivers" boat and you need to know how to drive it at higher speeds... So with the "new" bottom, there is less overall lift which tames it down and is more controlable with high power. Also, there has been zero negative aspects from this bottom change, even with smaller power. Rough water handling hasn't been sacrificed either. Another benefit from the change is that it requires almost zero tab input to keep level (depending on your load distribution) which in return is less drag which will equal more speed. I hope I answered your question. |
well gents ...... im certainly not as knowledgeable as you all are but
here goes i am still in the small class with a 26 ft nu era but this boat is amazing...... i dont have to trim out as far to get speed like i did in my old sled and someone made a comment about the boat just slowly lifting and the speed climbing and i still dont have the right prop soon to be rectified......... i purchased a 24 p for everyday running and a labbed 26 from cutting edge propellers i find that i can get a bad chine walk if i trim out to far back the trim off and feel her fly was out last weekend and got 68mph in dead flat water with no wind or ripple 2 old carcasses and a full tank is fuel i am impressed i zero my tabs and the slightest touch is all it needs to make the hull dance into instant response combine that with a bit of steering and i swear it feels i could carve a turn at WOT i cant wait to go out tomorrow,,,,,,,, |
Had the new boat out on Castaic on Saturday....had some wind chop and the boat ran soooo nice. Can't wait for Havasu in a few weeks!!!
Schweeng- did you buy the 2750? in the picts?
Uncle Dave |
In the pictures??
Yes I bought a beautiful 04 2750..... love it! I'm back on the water....:evilb: |
(Post 3109614)
In the pictures??
Yes I bought a beautiful 04 2750..... love it! I'm back on the water....:evilb: That was a sweet one too. One of the nicer ones Ive seen come up for sale. Congratulations! & Welcome back. How any Laveys does this make for you? Dave |
3rd one...
1st single 29 ever made 1st twin 29 ever made and this one..... http://images.traderonline.com//img/...mb_550x410.jpg Besides my twin step Cig this is the cleanest used boat I have every bought. Uncle Dave you doing the SCOPE run at Lake Mead??? Come on its Fathers day weekend. |
(Post 3109627)
3rd one...
1st single 29 ever made 1st twin 29 ever made and this one..... http://images.traderonline.com//img/...mb_550x410.jpg Besides my twin step Cig this is the cleanest used boat I have every bought. Uncle Dave you doing the SCOPE run at Lake Mead??? Come on its Fathers day weekend. I may- issue is I have the whole week after off- and its going to be hard to put the 2 back to back. Enjoy! Curious- Why did you get off the cig? Guys that own them are like cult members. Centless- most of these boats neither like, or need lots of positive trim and if you do do that it starts moving around on the pad. Keep it neutral or ever so slightly above that and youll be sailing along efficiently and likely faster than the "next guy" with the same power and length. |
| All times are GMT -5. The time now is 05:05 AM. |
