Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Help Needed - UK >
Help Needed - UK
Help Needed - UK
Old 11-09-2005 | 12:59 PM
24degrees's Avatar
Default Re: Help Needed - UK
Originally Posted by CIG3
We have two 27's. One with TRS and 350Hp small blocks runs around 62-65mph. THe second boat has stock 260's with alpha drive and runs in hte 50's. P.M. me and I'll try to help you our. I can see some changes you need ot make right off.
A>B>
Any chance of seeing pics of your 27's?
Thanks,
Aaron
24degrees is offline
Old 11-14-2005 | 10:01 AM
CIG3's Avatar
the 27 will run very neutral by nature. Raising the "x" will not help your ability to carry the nose with the weight forward. I would consider an 80-90 gallon belly tank to achieve better balance with your set-up. The "X" will natually go up with the bravo change, about 2" with 34" centerline.
CIG3 is offline
Old 11-23-2005 | 02:47 PM
There is a 27 Magnum in my club that runs 65mph on radar with stock merc. 350/260 mag carb motors. It has Bravo one drives mounted at a conservitive x-dimention. I expect my 350/450 motors to push 80mph.
27 MAGNUM is offline
Old 11-23-2005 | 06:25 PM
Some of the guys on http://www.boatmad.com/forum know the boat very well and used to race against it, might be worth asking.
http://media.boatmad.com/gallery/v/l...gnum_.jpg.html
MadMat is offline
Old 11-24-2005 | 03:47 PM
any 27 magnums out there for sale, be great with out motors, a project boat but the hull in great shape. thjanks in avance
jr
thedonz is offline
Old 11-24-2005 | 03:54 PM
This one is the only magnum I've ever heard of over here - that's not to say there's no others, but this one (which was always beautifully prepped) is definately the most desirable.
MadMat is offline
Old 11-24-2005 | 05:17 PM
stupid guess but wouldn't better and longer trims tabs help with speed gain
jr
thedonz is offline
Old 11-29-2005 | 03:19 PM
Hi Guys,
thanks for all the comments.... My current top choices are:
1. New pair of 350's rated at 400HP+
2. New pair of 387 Strokers rated at 400HP +
Anyway know of a good Small Block engine builder in the USA??
I have my credit card at the ready...
Cheers
Geoff
geoff@hotchilli.com is offline
Old 12-03-2005 | 11:39 AM
Originally Posted by [email protected]
Hi Guys,
Cheers
Geoff
Zul has built hot-rod small blocks (Armed and dangerous race boat in the early 90's), try him. Richie Zul; 631-491-7268 - I do not have firts hand experience with his motors, but that was a strong race boat powered with his small block motors. Good luck.
Stephen
Smarty is offline
pocketchange22
10-08-2008 05:03 PM
rockstar38
6
08-04-2008 09:37 AM
ext2gtx
Sea Ray
3
04-29-2008 08:11 AM
DJD
06-10-2004 12:31 PM
Formula Outlaw
05-06-2004 08:30 PM
