-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   question for the mag pros (https://www.offshoreonly.com/forums/magnum-marine/128973-question-mag-pros.html)
nocigarette 05-01-2006 06:26 PM
well i ran the mag yesterday,,,,all i can say is it was a ruff windy day.....Perfect for a test run. Ihave a quetion concerning my oil pressure and oil temp whats normal for my application,,,,,540 na 700 hoarse
how about it mel, you always have good info for me
Buy the way i rang a solid 78 on gps in a nice 3ft chop with the wind at my tail.....
24degrees 05-02-2006 12:01 AM
Re: question for the mag pros
78!..........nice.
nocigarette 05-02-2006 05:22 AM
im still rich as hell my transome was black when i got back.....Coming off plane it blubbbers and barks, i know i have room to go down
thedonz 05-02-2006 07:48 AM
awsome #'s....3 ft chop for that boat is nothing ...they sure do love the ruff ...
Jmemoli 05-02-2006 11:42 AM
what kind of RPM were you seeing ?
What prop are you turning ?
Just curious - Taking mine out in a few weeks .
78 mph , not bad !
Mag27 05-02-2006 03:29 PM
Nocig,Sounds like your off to a good start.I cant tell you a whole lot,I dont know your set up,X dimension gear ratio prop size totel advance on the dist.type of ignition your running how much trim your using how much tab you use,all makes a big diff.I had Vixen out yesterday to run chase boat for a new boat being tested here in fort myers and i ran my 15.25x16 prop with my 540 mech eng.this is my hottest set up and built almost like yours.It will turn up 6200 at 85 gps,now if i put on my 15.25x28 prop she will turn 5400 at 79 gps,so you can see props make a big diff.How does it react if you hit the throttles at 30 mph,it should set you back in the seat or you got to much prop.As far as temp.goes i run 110-120 and oil pressure 70 to80 while iam running hard and 60 when i come off plane,but thats the way I like it. Mel
nocigarette 05-02-2006 03:29 PM
the motor is rich as hell i know i can lean way more, but i am waiting for my tuning guy to come back in to town.....The boat was bought from a propeller builder and he has a bunch of numbers stamped in the prop..
I will take a picture of the numbers if ya guys want to know pitch,
One thing i will say is holy f%(* does that boat love ruff water, you could see the speedo jump as soon as i got in 3 footers, just chewed them up.
My timing isnt quite right yet either i know i can see an honest 82-85 with more tuning
nocigarette 05-02-2006 03:33 PM
posting at the same time mel.....
Your right pins ya in the seat from 35-40 to about 70 then it is all in the drive trim... tuning guy said the same thing....(this winter you need more oil pressure 50 pounds is hoarse sheet)
nocigarette 05-02-2006 03:34 PM
Oh yeah my rpm has never got over 5500, but i dont think my drive was up enough, i am still getting use to this crazy bastard.......WOOOOOOOOOOOW what a ride
Mag27 05-03-2006 01:57 PM
Nocig,sounds like your having fun now.My props are both Bravo 1 four blade lab finnished,i had a hydro motive 15.5ox26 and wouldnt work at all and got rid of it.I only ever run one race with my 540 that was in 2002 in P4 and got a DQ and went back to the 502 an 509 engines in Vixen.I know 80-90 is a real rush in open boat,but things can happen so fast,and you cant do anything but ride it out.Have fun but keep it safe.I guess i sound like a old woman but i been their and i know that feeling when seconds seem like hours and your on your own. Mel
