Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
A cool Starfire... >
A cool Starfire...
A cool Starfire...
Old 09-18-2007 | 05:44 AM
Originally Posted by h2oboater
The 496 mag dosn't have alot of aftermarket parts around but Tyler Crockett here in Michigan might be abel to help you, he worked with the GM Powertrain people to develop the 496 for marine use. Here is his web site. www.crockettmarineengines.com
Thank's for the information i'll see it!!
But,why does not have 496 mag a lot of after market parts?Is not a goog engine?And for you is it better to put this one or the "old" 454 magnum 420hp?I'm very uncertein,because i would like to know which engine gives me more performance and more noise(i love rumbling)....could you advice me?Thank's Federico.
mr.scrich is offline
Old 09-18-2007 | 05:50 AM
Mag27's Avatar
If you want big blocks go with 2 540,easy 650 hp each and all kinds of parts out there.
Mag27 is offline
Old 09-18-2007 | 07:07 AM
Mag27's Avatar
Sorry about that kinda over kill an 540s get kinda exspensive too.One the older 454 mag or hp engines bored out 60 with a good cam 10-1 comp.a 750 race carb and a set of big ovell port heads will get you 500hp with no problem and all kinds of them in the junk yards if you take the time to look.I been looking for a junk 496 with a good crank for the last year for a project i want to play with and still havent found one.I guess there better than i give them credit for,but i still think there a poor eng.,for a boat eng.
Mag27 is offline
Old 09-18-2007 | 07:52 AM
Stormrider's Avatar
JC Performance Engines
for 496 upgrade packages try www.raylarengine.com
Stormrider is offline
Old 09-18-2007 | 10:29 AM
h2oboater's Avatar
The big block chevy started life in 1965 as a 396cu it has since grown to [427-454-502] with many parts that are interchangeable, and have been raced in every form of motor sports over 40+ years. This new generation big block has only been around less than 10 years and has only been used in production trucks & marine use. [never the Corvette] Being from Detroit many of my friends work at General Motors, the word is this new generation big block [496] may be going away soon, and with GM Powertrain only to make big cubic inch small blocks for production marine, & truck use. Its not a bad engine but the aftermarket manufactures have not jumped on this engine and make the parts like they did for the good old big block that GM still sells as a aftermarket as well as Mercruiser. I would stay with the tride and true big block like the merc 502 Hp or update your 330, 454cu just my 2 cent's
h2oboater is offline
Old 09-18-2007 | 06:53 PM
magnum27's Avatar
http://pirateoffshoreracing.googlepages.com/
magnum27 is offline
Old 09-18-2007 | 06:54 PM
magnum27's Avatar
http://www.superboat.com/teams.cfm?a...ail&teamID=155
magnum27 is offline
Old 09-18-2007 | 08:33 PM
mr vinyl's Avatar
Default 454's...575 hp
Just heard back from Jeff Haylet that the 454's that he had redone for the 31 Sprit should produce around 575 HP...10-1 compression,solid lifters,big cam. We will see...hope to have the boat in the water later this month for a test run
I will post pictures later in the week. Bud
mr vinyl is offline
Old 09-19-2007 | 04:49 PM
Thank's for the advice h2oboater...i've understood that you prefer 454 or 502,but also 496mag (425 hp) run in P1 championship with Chaudron team and for this reason that i've asked you about them!!
For you because a new racer team in a new competition has chosen 496mag (425ho) and not 502 model?Becouse are they better than 502??this is the question that i ask to myself!!!! ...bye federico
mark30h
Classic Offshore
13
10-22-2006 12:55 PM
woz58
Magnum Marine
25
09-01-2006 10:49 AM
Jmemoli
Magnum Marine
65
07-24-2006 03:42 PM
bennyp
1
07-09-2004 10:05 PM
