Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Crusader Scorpion >
Crusader Scorpion
Crusader Scorpion
Old 07-19-2009 | 07:33 PM
mr vinyl's Avatar
Default Crusader Scorpion
Need some help from you engine experts....1973 25 Magnum Sport.fresh water with a SS 300 HP Scorpion Crusader # 40152 with a 270 T Volvo drive.I have been told this motor is based on a small block LT Corvette .need to know is it worth refreshing and what can be done to increase HP...or is it better to put in a big block which means new exhaust and plugging current ones etc.
Attached Thumbnails Crusader Scorpion-25-ft-orange-mag.jpg   Crusader Scorpion-img_0266.jpg   Crusader Scorpion-img_0267.jpg
mr vinyl is offline
Old 07-19-2009 | 07:59 PM
BUIZILLA's Avatar
instigator
it has an auto cast intake, auto distributor w/vacuum can and an automotive quadrajet.... may be nothing more than a 350/300 car engine... the LT1 engines had solid lifters up to '72 then hyd from 73-on... if it's a flat top small crown w/ 4 valve reliefs its 10.25 comp, if it's a flat top, crown, with 2 valve reliefs, it's about 9.5 comp, dished was 8.5 comp.
BUIZILLA is offline
Old 07-20-2009 | 07:36 AM
Mag27's Avatar
Drive won't take the torqe of a big block.It will slip,if its much over 350hp.
Mag27 is offline
Old 07-20-2009 | 11:30 AM
Default Crusader Scorpions
Great engines. Had 2 in my Magnum. They are basicaly 350-300's/ They do have 4 bolts and pink rods. mine had forged pistons and 194 valves. The most redeeming feature of your engine is the exhaust manifolds. they are monel and were made by Riva Boat Co. in Monte Carlo. Good luck
sshriber is offline
Old 07-20-2009 | 04:41 PM
h2oboater's Avatar
Back In The Day the Li'l SMIDGEN & WOLVERINE Mags had those manifolds with there home made OT pipes, they were loud !!! Scott now that I have yours back, the Mag will have that classic look.
Attached Thumbnails Crusader Scorpion-scan0049-ls80.jpg   Crusader Scorpion-mag-ot.jpg
h2oboater is offline
