Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Original waterline stripe width >
Old 06-04-2010 | 06:56 PM
Default Original waterline stripe width
i've just completed stripping and redoing the entire bottom on the Magnum 27, and want to stripe the side before it gets used . . .
Were the original stripes singe or double, I've seen pics of both, and what were the widths of each?
Mario L. is offline
Old 06-05-2010 | 07:02 AM
My 74 Maltese has double water lines. I will measure when I pick up the boat later today. I think the double was used in case you were carring heavy "cargo".
Bigbroadjumper is offline
Old 06-05-2010 | 09:59 PM
24degrees's Avatar
Mario....the double stripe was an option. The single stripe was 2in, I believe....
FWIW: I've seen some very early boats, like yours, that had a different stripe....hard to explain though...
24degrees is offline
Old 06-06-2010 | 09:30 AM
h2oboater's Avatar
Aaron The first Lil Smidgen looks like it had a 2" stripe.
Attached Thumbnails Original waterline stripe width-mag-l-s-ls51.jpg   Original waterline stripe width-mag-l-s-ls17.jpg
h2oboater is offline
Old 06-06-2010 | 09:48 PM
mr vinyl's Avatar
Default More stripes
I have seen a Magnum with a stripe just under the rub rail. Bud
Attached Thumbnails Original waterline stripe width-27-sport.jpg   Original waterline stripe width-28-maltese.jpg
mr vinyl is offline
Old 06-07-2010 | 12:39 AM
dammmagnum's Avatar
H2O
My 73 sport had a single 2" stripe also.
When we repainted the hull, we kept the original stripe and repainted the purple.
will try and post a photo after it was repainted.
Thank you
Jim
dammmagnum is offline
