Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Volvo Drive ratios >
Volvo Drive ratios
Volvo Drive ratios
Old 10-12-2010 | 08:41 PM
Default Volvo Drive ratios
Does anyone recall the ratio of the Volvo drives used on the early Magnum 27s and the Cigarette 27SS . . which IRC is the same hull.
Mario L.
Mario L. is offline
Old 10-12-2010 | 10:02 PM
h2oboater's Avatar
Mario L.
Mario,, 1.61:1 is the gear ratio. [230-260 HP 1.61:1 gear ratio] 14 x 23 14 x 23 15 x 21 props..
[290 HP 1.61:1 gear ratio] 14 x 23 14 x 23 14 x 21 props.. The prop sizes are just a good starting point. Mark
h2oboater is offline
Old 10-13-2010 | 12:33 AM
i have a 290 with 1;61 running a 14.25x23 ss bronson and hill left hand prop solid hub
innerrage is offline
Old 10-13-2010 | 05:56 AM
Perfect, thank you! I'm chasing down a couple 280B drives to replace the broken 250s on my boat. Then it's onto developing a single ram power tilt!
Mario L. is offline
Old 10-13-2010 | 08:17 PM
mr vinyl's Avatar
Default Tilt
Takh to Roger Munn,he has developed a number of ram tilts. Bud
mr vinyl is offline
Old 10-13-2010 | 11:29 PM
dammmagnum's Avatar
The Volvo trim set up I, had came off of Roger's Jolly Roger Sport when he converted to the MDS Speedos
The system worked great using Merc trim rams,, i think at the time they were Merc outboard trim rams
Hope this helps
Thank you
Jim
dammmagnum is offline
Old 10-14-2010 | 11:45 AM
I have pics.............
hallj is offline
Old 10-14-2010 | 12:00 PM
h2oboater's Avatar
Holding out again on us!!!!!!!
Old 10-14-2010 | 03:08 PM
mr vinyl's Avatar
Default Question...answer
This is one great site...ask a question and you get an answer. Bud
mr vinyl is offline
