Magnum Weight
Old 01-16-2012 | 01:38 PM
mr vinyl's Avatar
Default Trailer for Magnum
I always prefer a triple Axel to a two Axel trailer...it is better to have 6 tires on the ground vs 4.They also trail better.Brought the Magnum Force down to Florida for the auction on a triple,did not even know it was there. Bud
mr vinyl is offline
Old 01-16-2012 | 02:16 PM
Thanks Bud i can't disagree with you but the place I will be keeping the boat has a restricted access and maonuvering a triple might be a bit challenging . I am going to build it with 5200lb axles so weight shouldn't be an issue and over rated tires should reduce my risk of blow out.
RG.
Rick G is offline
