Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Single vs Twins >
Single vs Twins
Single vs Twins
Old 04-05-2012 | 09:09 PM
Thanks for all the input.
I've decided to stay with twins.
And go with twin 350 Mag MPI CPO Horizons with Bravo III's & silent choice.
Bullet proof reliability & warranty.
Flitzr1 is offline
Old 04-06-2012 | 10:13 AM
mr vinyl's Avatar
Default Twins
Good Choice,...see I told you the forum was the best place to get some good info on whatever you question is. Bud
mr vinyl is offline
Old 04-10-2012 | 12:19 PM
Originally Posted by Flitzr1
Thanks Kalaazar, I'ld like to see pictures of your motors installation w/ remote oil filters & how you installed & ran the power steering. Your set up is similar to what I'm considering with the 72. I'm researching the single to understand the pros & cons. I'm most likely will stay with the twins. If you can't post pictures here just add @gmail.com after my member name to send pictures to my email address...
Here you go - my twin 383 set up on Bravo One drives with Mayfair full hydraulic steering.
Attached Thumbnails Single vs Twins-poole-20120406-00032.jpg   Single vs Twins-img-20120310-00006.jpg   Single vs Twins-poole-20120406-00027.jpg
Single vs Twins-poole-20120406-00028.jpg   Single vs Twins-img-20120409-00037.jpg
Kalaazar is offline
Old 04-11-2012 | 12:06 PM
Ian,
You're a classy bloke!
Jeff
hallj is offline
Old 04-11-2012 | 12:31 PM
Jeff,
Your very kind, however to me the fun is in the build and the use is "Almost" an anticlimax ! After all water spoils boat does it not.
Ian
Kalaazar is offline
Old 04-12-2012 | 02:50 PM
Joules's Avatar
My 1971 "restromod" 27 Sport has a new pair of 383 ci`s on Bravo 1 drives with full power steering.
I like the sound of twins, the added security for Offshore use, a pair of handed props in place of all the power turning one way. Should I have to work in the engine compartment, 4 bolts on each side of each motor removes the Stainless Marine exhaust manifolds and I have all the space I need. Remote fit the oil filters and remote fit the block and manifold drains, what else do you need to get to that requires all this space I keep hearing about ?
Anyway that my view for what it`s worth
Kalaazar
That is pretty much identical to the way mine is setup; twin 383's right on 500HP each through Bravo 1 drives.
Julian
Joules is offline
Old 04-12-2012 | 03:24 PM
Julian
Fantastic, please help me out here as I have not run the boat yet. How high are your drives?, what engine RPM do you Max. at?, What size props are you pulling ? 3 or 4 blade? and the big one WHAT IS THE SPEED.
Ian
Kalaazar is offline
Old 04-12-2012 | 09:14 PM
Thanks, Nice looking. Like functional Jewelry.
i'm going fly by wire & mpi with vessel view display.
My test boat is Verado powered with smartcraft.
I can only compare it to paddle shifters vs 4 speed in a performance car & the amount of data is amazing...
Flitzr1 is offline
Old 04-12-2012 | 09:47 PM
Thanks for sharing...gives me some answers to questions I have on my project....your thoughts and suggestions are welcome.
http://www.offshoreonly.com/forums/f...or-update.html
I agree...however to me the fun is in the build and the use is "Almost" an anticlimax ! After all water spoils boat does it not
sprink58 is offline
Old 04-13-2012 | 12:03 PM
Jeff,
Ian
"Almost" will turn to "definite" when you burn up your Barclaycard filling the petrol tanks!
I'm "chuffed to bits" to make back to Blighty this summer!
I'll take care of the throttles, trim and steering. you guys can sit back and enjoy your Pimm's and lemonade.
Jeff
hallj is offline
