Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
paint decision >
paint decision
paint decision
Old 10-13-2013 | 09:30 AM
Will be goong thru the whole boat.wiil be cutting and replacing floor,stringers,hull will be painted,dash is going out,seats will be different style,it is a lot of work .it would not shift out of gear,drop the drive yesterday i hope i can find parts for this drive.will be taking the transmission out today.the 454 will be build to 496 stroker.will try to make it go 80mph.
Thunder 2013 is offline
Old 10-13-2013 | 09:58 AM
h2oboater's Avatar
Is it a Sternpower drive? If it's a mechanical in the drive shifter they are a pain & parts may not be available, I had two Klem boats with them. The Sternpower drives that use a transmission are bullet proof .
h2oboater is offline
Old 10-13-2013 | 10:24 AM
it is a sternpower with borg warner transmission(not sure of model) lever on trans moves back and forth but it stays in gear.I think it's a sternpower 84sp,has a cleaver style prop beat up looks 15x21,What speed you think i should be getting
Old 10-13-2013 | 12:19 PM
Hi h2oboater do you know where i can look for stenpower drive parts the prop shaft seal was leaking i just pulled it out and it has no part # on the seal.
Old 10-13-2013 | 10:32 PM
h2oboater's Avatar
Seals & bearings are common industry stuff like you could find at Mc Master Carr. For hard parts try here.
http://www.sternpowr.com/
And this place may have parts & info.....
http://stark.golocal247.com/biz/jtm-...sparta-oh/2054
