paint decision
Hi everyone,recently bought a 27ft magnum marine "LANCER" as a huge project,Will be doing major modifications on the hull,interior,deck,dash,custom paint and much more, so my question is what would be the best paint to be used on the boat.My issue is is painting the bottom of 70+mph boat what's going to work and hold to the bottom?Thank's everyone in advance!
I sprayed it. Glass Dave here on OSO is the expert, here are some links about PPG paint. Before you paint check all the wood [stringers,, transom] for moisture, most of Klems boats used poor wood & have rot.
http://www.offshoreonly.com/forums/f...ml#post3692796
http://www.offshoreonly.com/forums/f...ml#post3692873
That will be the first things to do i will remove all the wood used +floor boat has been sitting since 96 when i picked it up it had about 30+gallons of water inside basicly i bought the hull only everything else will be replaced/repaired and i'm also chanching the desighn on top and will open the deck area toward the front about 2 feet will be a major very long project but i hope at the end it will be one of a kind!
