Look At The Size Of This Thing !
Old 10-17-2005 | 11:55 AM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Re: Look At The Size Of This Thing !
OHH and don't forget
THREE YEAR WARRANTY
nuff said...
teaguecustommarine is offline
Old 10-21-2005 | 11:27 PM
Donzi38ZX's Avatar
All the info is on their website. Looks like most of us would need the PC1200 or PC 1700. They are what is recommecnded for big blocks.
From the website:
PC 1700 Odyssey Battery
PC1700 Drycell Battery Specifications
Marine Super Heavy Duty & Fleet Applications RV's. Group 27 Replacement
PERFORMANCE
Category Super Heavy Duty / Marine
Ahr (amp hours) @ 20 hr. rate 68 Ahr
Pulse Discharge (HCA)
5 sec. 1700 A
10 sec. 1540 A
20 sec. 1355 A
HCA @ 80ºF (27ºC) 1325 A
CA @ 32ºF (0ºC) 1175 A
CCA 875 A
Reserve Capacity @ 25 A 142 min.
Cycle Life (Deep cycle capability) 400 @ 100% DOD (depth of discharge)
500 @ 80% DOD
Temperature Range -40ºF (-40ºC) to 176ºF (80ºC)
Resistance at 1 kHz @ 77ºF 3.5m Ω
Short circuit current 3500 A
Terminals SAE combination post with 3/8” top thread
Max. installation torque 60 in-lb. (Stainless steel top thread)
DIMENSIONS
Length 13 in. 13.0 in. 330.7 mm
Width 6 5/8 in. 6.62 in. 168.2 mm
Height* 6 15/16 in. 6.93 in. 176.0 mm
Weight 60.9 lb. 27.6 kg
*Height is measure to top of terminal
Other Features
3 year full warranty in heavy duty marine, automotive/commercial applications
Available with protective metal jacket (PC 1700 MJT)
Features non-corrosive, brass SAE automotive terminals (add 0.75”)
Can be mounted in any orientation (not recommended for inverted use)
12 year design life with 6 to 10 year service life
Fully charged out of the box
2 year shelf life @ 77ºF (25ºC)
Available with 5/16 stainless steel stud terminals
Donzi38ZX is offline
Old 10-25-2005 | 11:12 AM
that is if your running the group 27,
i know a few people using the 925 battery
running twin 525 mercs with no problems
i have even seen one of the west coast race boats
with two 925's in it and they even won
the race (not that the battery had anything
to do with it)
Old 11-14-2005 | 10:41 AM
Joe's Avatar
Joe
Offshore Cowboy
Default Re: 1700-ca $245.10
Originally Posted by teaguecustommarine
1700 cranking amps for 5 seconds -------------------------------
1540 cranking amps for 10 seconds ------------------------------
1355 cranking amps for 20 seconds -----------------------------
Short circuit current over 3500A ---------------------------------
68 amp hours ------------------------------------------------------
142 minute reserve capacity with 25amp load-------------------
With SAE automotive terminals -----------------------------------
Length 13.0" --------------------------------------------------------
Width 6.5" ----------------------------------------------------------
Height 7.5" including terminals -----------------------------------
Weighs 59 lbs ------------------------------------------------------
this battery is probably what i would use if i had the BAD MAMMA JAMMA sterio system
Bob,
I need 2 31's (7 JL Amplifiers, 6 Woofers, 16 pairs of 6 1/2's, capacitors for each amp etc... etc...). How much for the two, incl. shipping to zip code 77002?
Joe
832-277-3661
Joe is offline
Old 11-16-2005 | 10:55 AM
Originally Posted by Joe
Bob,
Joe
832-277-3661
I recomend
PC 2150 Specs:
2150 cranking amps for 5 seconds
1985 cranking amps for 10 seconds
1695 cranking amps for 20 seconds
Short circuit current over 5000A
100 amp hours
200 minute reserve capacity with 25amp load
3/8 in. (9.5 mm) corrosion-free stud terminal
Length 13.0"
Width 6.80"
Height 9.40"
Weighs 75 lbs
Rugged military construction
Limited 4 year full warranty
Container and cover made from oil resistant plastic
US DOT and IATA certified non-spillable
Shipped fully charged - just install and go!
$293.00 ea
Old 11-16-2005 | 01:52 PM
Joe's Avatar
Joe
Offshore Cowboy
I recomend
PC 2150 Specs:
100 amp hours
Length 13.0"
Width 6.80"
Height 9.40"
Weighs 75 lbs
$293.00 ea
Thanks, Bob.
I'll give your guys a call early February to get them here before the warm (boating) season arrives.
How long should I consider it taking to have them shipped to Houston, TX 77002 (so I can predict when to call in the order)?
Joe
Joe is offline
Old 11-21-2005 | 11:11 AM
Thanks, Bob.
Joe
your probably looking at 3-4 days
Old 12-30-2005 | 08:04 PM
FeverFan's Avatar
Default Re: The Mac Daddy 2150-ca $298.97
2150 cranking amps for 5 seconds -------------------------------
1985 cranking amps for 10 seconds -----------------------------
1695 cranking amps for 20 seconds -----------------------------
Short circuit current over 5000A ---------------------------------
100 amp hours ----------------------------------------------------
200 minute reserve capacity with 25amp load ------------------
3/8 in. (9.5 mm) corrosion-free stud terminal ------------------
Width 6.80" --------------------------------------------------------
Height 9.40" -------------------------------------------------------
Weighs 75 lbs ------------------------------------------------------
*FOUR YEAR WARRANTY*
2150-CA is a Group 31-size deep cycle. lasts up to 10 years in engine-start operation versus 2-3 years as compared to similar batteries. provides greater cranking power
this would be a fantastic battery for large sterio systems
Bob (this is Joe, not FeverFan - just logged on at his house),
You suggested a different battery (other than the one mentioned above) and I'm not sure why. I was wondering why. As I mentioned in my last post, I'm now ready to order the batteries. Give me a call at 832-277-3661 or PM "Joe" with the best number to reach you next week (as of Tue). I'd like to discuss it more in depth - and know the "name" of the batteries etc... before ordering with you. I have been told to buy another brand, but would like to run all the traps first - considering "your" batteries may suit my needs mo'betta!
FYI - I met you a few years ago in Sarasota (after having a phone conversation a few months prior re: my boat mechanic b!tching about the motors another guy I boat(ed) with had from you - then, that guy lost his boat, wife and medical license - all in the same month. So, his engine problems were, most likely, due to "operator error," I'd assume - considering the turn of "other" events! ).
Anyway, I enjoyed speaking with you then and appreciated you taking the time to stop and have a conversation with a (young punk) "non-racer" cig. owner!
Joe (not FeverFan)! haha.
FeverFan is offline
Old 12-31-2005 | 09:28 PM
Joe's Avatar
Joe
Offshore Cowboy
Bob, Plz. disregard my previous post (via FeverFan). I found the website on Page 1. The site answered my questions. I'll give you a call Tuesday to order. Thanks, and sorry for the long-winded previous messsage!
Joe is offline
Old 01-05-2006 | 11:53 AM
Joe's Avatar
Joe
Offshore Cowboy
Thanks, Bob (Adrian!). Just bought a pair of the PC2150's!
Joe is offline
